Busted Y pipe
Old Sep 7, 2010 | 07:31 AM
b4u2's Avatar
b4u2
Default Busted Y pipe
I have only had this 2003 Road King for about a month. It has 16k miles on it now. I rode it 35 miles saturday, parked it for four hours, then went to leave. Got to the first stop sign and took off then things started sounding odd. I looked down and saw my muffler hanging by the pipe wrap. Luckily they were wrapped or it would have dropped all the way to the ground. I can only imagine what kind of problems that would have created.
So what are my options? I am low on cash right now so looking for cheap....I know nothing about welding so not sure if this could be welded until I can get something different. I could buy stock off Ebay for less than $100. I also came across Fullsac.com for $189 plus S&H. Any other options for under $200?
Old Sep 7, 2010 | 07:41 AM
chiefparry's Avatar
chiefparry
Make it a true dual and go with the fullsac, will run and sound better.
Old Sep 7, 2010 | 07:44 AM
Guntoter's Avatar
Guntoter
Just a guess, but I bet they had wrapped that pipe to cover up the crack and leak before you bought it. Why it cracked would be the question. I hear people on here talk about broken front motor mounts a lot, so maybe that caused it or the muffler bracket had broke or came loose allowing the muffler to swing around for a while. Check ebay, I would think there would be numerous exhaust systems for sale on there from take offs for other exhausts. Just have then send you pics of all the pipes, especially the 2 Y locations so you can see if there are cracks there already. Also, make sure the pipes are the ones prior to the oxygen sensor, or you will need something to plug the holes with.
Old Sep 7, 2010 | 08:45 AM
smokindave's Avatar
smokindave
Check all your motor mounts, now(especially the front). Your best bet is to buy a used set on e-bay, welding them won't work.
Old Sep 7, 2010 | 08:48 AM
axel black's Avatar
axel black
coworker had his break at 14K. He found area dealers had 2 or 3 in stock. His bike is stock through out, and replaced it himself. Like Guntote said, check motor mounts and use e-bay, maybe negate the Y pipe. I like the system on mine and plan on keeping for as long as it looks good, no yellow on chrome anywhere after heat shields and have 20K on pipes.
Old Sep 7, 2010 | 11:14 AM
mtclassic's Avatar
mtclassic
I have a take off from 2006 Roadking I will sell for $30 plus shipping. Took off early and replaced with supertrapp 2;1
Old Sep 7, 2010 | 02:50 PM
pit1600's Avatar
pit1600
welding is not working. I changed mine on my '04 two month ago... too expensive part!!!
Old Sep 7, 2010 | 02:54 PM
b4u2's Avatar
b4u2
Will the pipes from an '06 work on an '03? If so I will buy them mtclassic
I will check the motor mounts tonight. I like the look and sound of the Fullsac but $$$ are a little short right now.
Old Sep 7, 2010 | 04:19 PM
grbrown's Avatar
grbrown
Thumbs up
I had the same problem with my old Glide and found a cheap replacement. Later I used a Fullsac and it worked so well I now have a completely new true dual setup. I think either of your options above should work for you. Here's to better times!
Old Sep 7, 2010 | 05:59 PM
mtclassic's Avatar
mtclassic
Yes the bagger pipes are the same on 03's and 06's. Do you need the Y pipe or the front pipe?
