Squeeky muffler mounts...
Old Sep 15, 2010 | 11:05 PM
racedvl's Avatar
racedvl
Default Squeeky muffler mounts...
They are making me crazy! Mainly on decell and now a little at idle. Do I need to just replace the rubber mounts (that's what squeeking) or is there a trick to quite them down? I turned them around in the bracket last night, and it made it stop. But by the time I got home from work today, they are starting to make noise again. 2001 FLHPI.... Thanks, Jason.
Old Sep 15, 2010 | 11:11 PM
voodoodrug's Avatar
voodoodrug
got it here too.
there where alot of posts about this awhile back I think. I think you can put something on them or replace..im not shure but I know what im going to try first..through them out and put true duals on this winter.maybe that will fix them?
Old Sep 15, 2010 | 11:13 PM
Gaspumpcity's Avatar
Gaspumpcity
Same problem here except the rubber grommet would slide out then start rubbing metal to metal muffler bracket to the muffler.So I glued the rubber grommet to the muffler so it couldn't slide out.
Old Sep 15, 2010 | 11:33 PM
racedvl's Avatar
racedvl
Originally Posted by voodoodrug
got it here too.
I have true duals now. So I dunno if that will help your cause.
Old Sep 15, 2010 | 11:39 PM
Rock Chalk's Avatar
Rock Chalk
Had the same thing at the start of the summer, I took the grommets out and switched them around a few different ways and haven't heard from them in months.
Old Sep 16, 2010 | 01:42 AM
Avmech97's Avatar
Avmech97
I use WD-40 or something similar on the metal bar that goes through the rubber part. It works for me. I have replaced the rubber isolators in the past but they just start sqeakin again so the lube trick quiets it down for a while.
Old Sep 16, 2010 | 04:57 AM
im's Avatar
im
pipes are intended to be able to slightly slide back/forth thru black rubber part.
If pipes are unable to slide with vibration of motor, possibility exists that increase tension could result at some other area due to binding. Increased tension could cause cracking or breaks in other areas of pipes or their mounting.
Old Sep 16, 2010 | 05:13 AM
dansflhti's Avatar
dansflhti
Usually once a season I remove mine and cover them in silicone grease.That cures them for a few thousand kms.
Old Sep 16, 2010 | 06:40 PM
mtbottles's Avatar
mtbottles
I had the same problem up till yesterday. Took me a few days to figure out where the noise was coming from. I just sprayed a little wd-40 on the bracket. So far so good.
Old Sep 16, 2010 | 06:44 PM
atrain68's Avatar
atrain68
Common problem. I spray them with what ever lube I have on the shelf once a year. Problem solved.
