SE Compensator
Old Sep 17, 2010 | 06:12 AM
classic53's Avatar
classic53
This is definitely going in after I get the bottom end back from darkhorse.
Dang 07 cranks!!!!!!!!!!!
Old Sep 17, 2010 | 06:36 AM
jkelley's Avatar
jkelley
Super easy job guy's. grinding the case is nothing! once you get her opened up you will see the lip and it is clear how much to take off from 9 to 6 "O" clock. I just did three of them last month and all owners were very happy. no need to remove the clutch at all. Carefully tape rags up to catch the metal grinding particles and use some shaving cream just behind the area you are grinding to be sure you stay clean. Flush to primary one time with ATF after the job and install the lube of your choice and you are good to go!
Cdal1
Apr 20, 2018 08:53 PM
rg_dave
Oct 15, 2012 08:12 PM
shortride
Jul 12, 2011 02:33 PM
SCJE8
Feb 18, 2011 02:44 PM
sifularson
Apr 4, 2010 07:05 AM
