Would True Duals be the answer?
Old Sep 22, 2010 | 07:52 AM
voodoodrug's Avatar
voodoodrug
puttin td on this winter cant wait! had some decel popping this summer,found the rubber trim around the air filter had started to deteriorate posabley do to some minimal oil blow by(very minimal not dripping),new air filter(k&n) a few cycles from the o2 sencers and popping gone,btw the dealer told me to change the spark plug wires but never did.
Old Sep 22, 2010 | 07:59 AM
db2753's Avatar
db2753
I have TD, Jackpot Mufflers, SE Air, & TTS can map. When stuck in stop & go traffic you still get toasty but the TD do help some.
Old Sep 22, 2010 | 08:32 AM
bubbleb's Avatar
bubbleb
Originally Posted by mazman
For the Frickin HEAT?? After fuelpac, PCV5, still hot as hell!! Decel popping too. Had the PCV dyno done, was fine for a while, then got hot again and decel popping. Got fuelpac map from VH. Still hot and decel popping. I have 09 FLHT with Heavy Breather, Rinehart 3 1/2 slip ons. Is there a difference in High Flow and Heavy Breather. I've been told true duals would solve everything. What do you guys think? Thanks!
sounds like it could be an exhaust leak.
Old Sep 22, 2010 | 11:24 AM
r8rs4lf's Avatar
r8rs4lf
Originally Posted by cvoultrahunter
R8
I've got 2010 SG w/ 103 stage 2 and heavy breather. Also thinking of going with V&H Dresser Duals. Love the look just can't decide on what slip-ons to pair with them. I prefer them on the louder side. Thinking of going with V&H Hi-Output slip ons but anxious to hear them first before dumping all the cash. What slip ons are you running with the dresser duals?
I have CFR's.
Don't believe the hype of loss of low end due to TD's. If there is any loss, I certainly can't feel it. For sure get a dyno tune. It made a huge difference in the way it runs.
Old Sep 22, 2010 | 12:08 PM
rg_dave's Avatar
rg_dave
It really sounds like your tune is off if you have popping on decel. I have the FM breather, PCV, and mufflers. I don't have any decel popping and the heat isn't a problem. I ride pretty much every day and had lots of days in the 98-100 degree range. Have you talked to the guys at fuel moto?
A friend has the rineharts td and they look and sound great. You will still need a good tune.
Old Sep 22, 2010 | 05:46 PM
jag1886's Avatar
jag1886
True Duals aren't going to solve your problem, they will just burn your leg equally on both sides.
You are running lean.
Old Sep 22, 2010 | 05:56 PM
sifularson's Avatar
sifularson
Decel poppng can come from too lean or too rich conditions. The only way to know for sure is to have a dyno tune done.
Otherwise, you can try different maps until you stumble onto one that works.
True duals will help somewhat but they won't solve the tune problem. if you have $400 to throw at it, you can put a set of duals on it anyway.
JMO
Old Sep 22, 2010 | 06:50 PM
mech-a-nic's Avatar
mech-a-nic
True duals helped witht he right side heat on mine left was never an issue
I have stage 1 intake kit, Powercommander and "Bub" true duals to 3.5 Rineharts. But mine is set a little rich droped temp a few deg. But SOUNDS GREAT NOW
liverdeluxe
Jan 31, 2018 08:35 PM
swifty
Apr 22, 2015 07:03 PM
Lilman
Feb 24, 2012 07:40 AM
hullhorr
Mar 20, 2010 05:16 PM
serverpimp
Exhaust System Topics
Mar 3, 2008 12:07 PM
