LED Headlights
Old Feb 1, 2011 | 09:28 PM
  #71
masterblaster's Avatar
masterblaster
Been riding home from work last two weeks at night through Miami traffic and some back roads along the Everglades ( pitch black except for the allagator eyes on the side of the road), these lights are the best $ I spent on the bike so far and I have spent much dinero on my bikes. Next up is the truck light for the 7" ebay light I bought for the Dyna.
Its been in the 80's the last 5 days, had a cold snap early last week it went down to the 60's.
Old Feb 1, 2011 | 09:35 PM
  #72
TexasJR's Avatar
TexasJR
Originally Posted by Opossum
If ya do that go ahead and order the LED bulbs for 'em or they'll be yellow lookin, don't ask how I know
I understand. The LEDs are much whiter. They also want an extra $100 for the LED bulbs....
Old Feb 17, 2011 | 02:36 PM
  #73
OlDusty's Avatar
OlDusty
I know the proper way and the HD instruction way is to wire the passing lamps to be on with the headlight but switch off when you go to the brights. Can any one offer some detail on how to wire it so the passing lamps stay on when you go to bright and when you are running dim? I would especially love to see pics of the wiring if you have them. This will be on a 2010 SG with the lamp brackets. Sorry bout the bad grammar all from iPhone
Old Feb 17, 2011 | 07:16 PM
  #74
hdramon07's Avatar
hdramon07
Here is the way it is commonly done on the EG's (also the way I did my Ultra). If you are adding passing lamps, you will most likely want to add the 'Spot' switch to your fairing cap panel You will also need to add a ground wire to the switch so the indicator light will operate. The easiest way is to remove & unplug the fairing cap & do the splice on your work bench. Easy to do mod.
What the ‘Factory Wiring’ diagram above doesn’t show is the yellow wire coming from the headlight circuit passes thru a
multi-connector behind the fairing cap (the small portion of the fairing that has the dash switches installed), just below the
accessories switch, before going to the passing lamp switch.
See diagrams on next page.
When low beam is on, the yellow wire is energized, passing power to the passing lamp switch/lamps. When high beam is
switched on the yellow wire de-energizes, turning off the passing lamps as well as the low beam.
To have the passing lamps stay on with the high beam, it is necessary to replace the power source from the yellow low
beam circuit with a power source that is always on with the ignition.
Two ways to do this:
1) First is illustrated in the diagrams above. Disassemble the fairing cap (requires the removal of the ignition switch). Cut
the yellow wire leading to the passing lamp switch and splice into the inbound power source to the accessories switch (the
orange/red wire). To avoid a short - make sure to insulate the cut end of the yellow wire coming from the multi-connector
– this will be hot whenever the low beam is on. Reassemble.
2) Remove the outer fairing. Find the multi-connector behind the fairing cap and disconnect. Using the proper technique,
remove the yellow wire and pin from the connector. For easier access to the connector, carefully fish the wiring harness
through to the front of the bike. To avoid a short – insulate the wire end/pin just removed – this will be hot whenever the
low beam is on. Put a replacement male pin on one end of a length of wire and insert into the slot the yellow wire was
removed from. On the other end of the wire, put a spade terminal. This spade terminal will be connected to the spade
terminal on the orange/white wire that is alongside the headlight socket/wires. The orange/white wire is always hot when
the ignition is on, so the passing lamp switch will always be energized. Reconnect the multi-connector, re-fishing the
harness if necessary. Reassemble the outer fairing.
NOTE: either method will energize the passing lamp switch whenever the ignition is in the ‘On’ –OR– ‘Accessories’
position. To save the battery – be sure to turn the passing lamp dash switch off whenever using the ‘Accessories’ position for any length of time.
Old Feb 17, 2011 | 09:20 PM
  #75
OlDusty's Avatar
OlDusty
WOW, can't thank you enough sir...buying you a virtual beer right now bro.
Old May 13, 2011 | 03:09 PM
  #76
hankus1369's Avatar
hankus1369
Default LED Lights
Your bike looks awesome, very nice PICs. Which headlight do you have (model)?
Hankus
Old May 13, 2011 | 08:13 PM
  #77
Twinrider's Avatar
Twinrider
I've had these lights for a couple months now and am very happy with them. They cast a wide, deep and bright spread of light even on low beam but don't bother oncoming traffic.
http://www.youtube.com/watch?v=Jj3qLJozbs4
Old May 18, 2011 | 08:37 PM
  #78
shredder22's Avatar
shredder22
Somebody please help me out here, lol. I just looked up the part # for these light for an 09 RKC and they want $525.00 for these LED's, is that correct? If it is is there anything less expensive with the same results? Thanks for any help....
Old May 18, 2011 | 08:41 PM
  #79
cardboard's Avatar
cardboard
Don't know if it will work in a Road King, but look at Post #64
Old May 19, 2011 | 12:00 AM
  #80
Twinrider's Avatar
Twinrider
If you buy from a place like Zanotti you'll get 20 percent off.
