Throttle Friction Screw...
Old Oct 12, 2010 | 10:02 AM
jsciullo's Avatar
jsciullo
Default Throttle Friction Screw...
Am I insane but isnt there a small screw on the underside of the throttle grip that adjusts the amount of pressure needed to twist the throttle? Just got new bars on my bike and I think the installer forgot to put the screw back in place. The throttle twists with little to no effort now - I like a little resistance. I think I remember the dealer telling me that I can adjust this with that screw.
Old Oct 12, 2010 | 10:05 AM
valvestem's Avatar
valvestem
Yes, there should be a rather large star-shaped plastic thumb wheel that is called a throttle lock. I don't know if the throttle-by-wire models have it, or if even installed on the current HD's.
Link: https://www.hdforums.com/forum/other...-assembly.html
wolfman 66's Avatar
wolfman 66
09 touring bikes have TBW no cables no tension screw.
Old Oct 12, 2010 | 10:13 AM
nigelgeast's Avatar
nigelgeast
The throttle lock should be there.
Old Oct 12, 2010 | 10:25 AM
jsciullo's Avatar
jsciullo
Sorry, should have mentioned that its a '09 Road King Classic.
Old Oct 12, 2010 | 10:32 AM
Neckball's Avatar
Neckball
I don't know about the TBW models but on the other Touring bikes, if you have cruise control there is no throttle lock. I'm guessing the throttle lock may have been on carb'd engines only, as well.
Old Oct 12, 2010 | 10:34 AM
roadgliderick's Avatar
roadgliderick
no u have TBW no throttle cable om your bike.
Old Oct 12, 2010 | 10:45 AM
jsciullo's Avatar
jsciullo
I dont know if I want to call it a throttle lock - maybe throttle friction screw is more like it. Before the bar change it took a little muscle to twist the throttle but now it twists with no effort. I believe this screw adjusts that pressure.
Old Oct 12, 2010 | 11:02 AM
Harleypingman's Avatar
Harleypingman
TBW or cable, there won't be a friction screw if you have cruise control since the friction screw/shoe defeats/interferes with the safety feature of the throttle roll-off switch.
Carl
Old Oct 12, 2010 | 11:49 AM
sargek's Avatar
sargek
The screw is a crude form of cruise control. Personally I think it was a monumentally stupid idea, but that's my opinion. I never used it on my carbed Wide Glide and had it backed off all the way. I use that little "paddle" plastic wrap-around cruise control that you slip on the right grip - works great.
