remvoving the front fender
Old Oct 14, 2010 | 05:07 PM
Scoobydoo_pj's Avatar
Scoobydoo_pj
Stage I
Default remvoving the front fender
Hey I have a dumb question I have an 05 Road King and need to know if I can remove the front fender without removing the tire
DAn
Old Oct 14, 2010 | 05:16 PM
lp's Avatar
lp
You can by squishing the fender together but you risk creating a dent or seam while doing so or scratching the fender all up.
Better to take the brake calipers and then wheel off first. My opinion of course.
Whatever method you choose make sure you tape up the fender around the mounts to keep scratches at bay. For removal and install...
lp
Old Oct 14, 2010 | 05:51 PM
jack49's Avatar
jack49
I found it easier to pull the wheel first.
Old Oct 14, 2010 | 05:53 PM
DamifIknow's Avatar
DamifIknow
I took my fender off without removing the tire. It wasnt bad. Just be careful.
Old Oct 14, 2010 | 05:55 PM
Primo's Avatar
Primo
Originally Posted by DamifIknow
I took my fender off without rmoving the tire. it wasnt bad. Just be careful.
Yeah. What he said.
Old Oct 14, 2010 | 06:08 PM
bigmack's Avatar
bigmack
changed my fender on my 03 rk a couple times without removing tire
Old Oct 14, 2010 | 06:09 PM
SamStone's Avatar
SamStone
It's so easy to remove the front wheel, why risk damaging the fender.
Old Oct 14, 2010 | 06:51 PM
head's Avatar
head
i didnt have a proper bike jack, so i have removed mine without pulling the front tire. its not too bad getting the fender out of the there. just be careful. the hard part is the tabs that are bent around the bolts that secure the fender to the forks. if you can get to where you can see them, get a long screwdriver or such and tap them back straight. its a lot easier then.
head
RKC1965
2014-2024 Touring Models
Sep 12, 2016 07:25 AM
sonar_chris
Nov 7, 2009 04:38 PM
XARAN
May 6, 2009 11:18 AM
linkey
Feb 3, 2008 03:10 PM
Mikeeeeeeeeee
Nov 2, 2005 11:30 AM
