Mastertune vs PC V
Old Oct 20, 2010 | 11:47 AM
iclick's Avatar
iclick
Originally Posted by JCleary
The other difference you should see is better fuel economy. PCIII's and most PCV's are running open loop all the time. The TTS will allow your tuner to program closed-loop running, searching for an AFR around 14.2. You'll have a cooler running bike that's efficient on the highway.
I understand the ease of a PCV, but I've never been able to wrap my head around removing the O2 sensors. Never made sense to me to ditch a tuning aid and run off only a map.
Fuel economy won't be measurably better with the O2 sensors connected than not, given a proper map either way. The stock NB O2 sensors do little more than act as a switch to keep AFR's at some point between 14.2-14.6:1, wherever you wish to set it in the software, and without them you still can maintain an AFR specified by the map created by a dyno-tune. The MAP and all other on-board sensors still work with the PCV attached and these adjust AFR for altitude, air-density and temperature, etc. I was able to get 50mpg on the backroads with my PCIII and PCV before adding Auto-Tune, with no O2 sensors attached. It is no better now with the accuracy afforded from running AT with its wideband O2 sensors, actually a bit lower since all gas in my area has changed to E10, which adversely affects mileage. I'm lucky to get 49mpg nowadays, usually 47-48.
Old Oct 20, 2010 | 11:49 AM
mjb765's Avatar
mjb765
Originally Posted by iclick
You can also add the Auto-Tune kit to the PCV, which also auto-tunes AFR's on the fly, sampling at 50x/sec. It may be a cheaper solution than T'Max and works very well. Be advised too that with non-TBW (cable) applications T'Max disables the ECM's knock-sensing feature, as well as the MAP sensor's full range of features, while the PCV keeps all on-board ECM sensors fully operational. I don't know if this is still the case with TBW bikes, but Jamie would know. He sells both.
Had PC-III a few years ago.....wasn't crazy about it. Maybe the newer ones are better. Liked the TTS much better..Thinking about the T-max for the on the fly sampling.
Old Oct 20, 2010 | 12:03 PM
Jim Dawson's Avatar
Jim Dawson
Originally Posted by dohadex
This is really a no-brainer...go with the PC-V.
"No-brainer"? Maybe for some but the TTS Mastertune leaves nothing hooked to your bike and allows the O2 sensors to do their job as intended by the guys that designed the engine. The TTS also has maps available that will match most common configurations. If you want to tweak it you can with their software. I also like fact that you can calibrate the speedometer and adjust the TBW throttle delay.
Old Oct 20, 2010 | 12:27 PM
frenchbiker's Avatar
frenchbiker
Originally Posted by sifularson
I went with TTS Mastertune. Just me but I didn't want an add-on part sitting under my seat. Why not just reprogram the stock ECM?
I installed the recommended calibration and the bike runs great.
Have you seen the Youtube video on how to install Mastertune?
Yes, it really was that easy!
It's as easy and as fast with the PCV if not faster. I did it several times to load new maps when I changed my slip-ons twice and my headers once. Takes 1mn each time.
With the PCV, I just like the fact that it doesn't reprogram the ECM, but piggybacks it. If I unplug the PCV, nobody can tell that I have one, and certainly not HD who could threaten to void the warranty in case of an engine failure.
One of these days, I'll get the Autotune module. I don't anticipate major improvements over the canned map I'm running now but I'll get closer to the optimal settings for my bike. More importantly, it'll save me $$ over a dyno tune. Many guys I know have spent big bucks on dyno tunes for no noticeable improvements, some of them ended up with worse results than before and they had to dyno tune it again (and pay again).
Finally, I'd be curious to compare the mods to a canned map suggested by Autotune to the mods suggested by a good tuner for $300 or more. I bet the 2 maps will be almost identical. All things being equal, I'll take technology over one guy's knowledge.
Old Oct 20, 2010 | 01:23 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Threads that are titled product XXX vs. PC-V always get my attention. As many of you know I have extensive experience tuning with both of these products as I work with them on the dyno every day. Both the TTS and PC-V are excellent products and are more than capable or providing a great tune. Saying either of these products does less than the other is better stated that they each do things differently and rather than say what TTS cannot do I would rather say what PC-V can. For example the PC-V has 240 tuning ponts per cylinder for fuel, igntion timing and AFR. With PC-V you can build maps individually for all 6 gears and by doing so this would give you 2880 individual tuning points (5760 tuning points if you use the Auto Tune module) You also have the ability to use a map switch to change between multiple maps, add dual Wideband O2 sensors with the Auto Tune module for real time tuning to the AFR you specify, and the PC-V also has a configurable input channel which allows you to setup your own table based on any 0-5V signal. These are all features that are not available with ECM flash based tuners. Another huge benefit with the PC-V is the broad range of calibrations that are available. For example, Fuel Moto has developed more maps for the 2010 Touring model alone than there are TTS calibrations for all twin cam models combined. That does not even take into consideration the maps that Dynojet has developed.
The best recommendation I can give is to do your research and choose a tuning platform that works within your needs and limitations. Most importantly use a tuning device that has the best support or that you have a willingness to learn. As always, we are here to help and if anyone has any questions just let me know
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Oct 20, 2010 | 01:42 PM
JCleary's Avatar
JCleary
Yeah, the multiple map thing is cool, especially if you want to run regular fuel and 100 octane, or NOS. And the PCV is definitely easier for the dyno operator to tune. No need to shut the bike down, load a map, restart and retest for results. When tuning at fixed throttle points one can make changes on the fly. Definitely shortens dyno time, and probably results in a more accurate map if the dyno operator isn't a perfectionist when using the TTS or SERT.
94ruck
Aug 24, 2017 10:01 AM
Tanker2
Jan 13, 2013 06:27 PM
Toliverpeterson
Jun 27, 2012 08:38 PM
10350
Sep 21, 2011 11:28 PM
Drail
Oct 27, 2009 08:48 PM
