idle cable
Old Oct 26, 2010 | 10:56 PM
djw's Avatar
djw
Default idle cable
What's the process for replacing the idle cable on an 02 rkc? has to be removed to route/install the cable.
Thanks for any assistance.
Old Oct 27, 2010 | 07:04 AM
1flhtk4me's Avatar
1flhtk4me
Yes you do have to remove the old one first.
I found it easier to remove the gas tank first,better visabilty.
I would check the throttle cable at the ball end at the grip.
I suggest getting a service manual for the proper adjustments.
Old Oct 27, 2010 | 08:16 AM
an Uncouth Barbarian's Avatar
I just replaced mine this past weekend, but I have an Electra Glide so the procedure is a little different. You'll need to do a partial removal of the gas tank which is fairly easy. Taking the handlebar controls and throttle apart is a little tricky, though. The best thing you can do is get the service manual for your motorcycle.
Old Oct 27, 2010 | 08:23 AM
mainshaft's Avatar
mainshaft
Also becareful not to lose the brass ferrel (spelling) when changing out the cable end in the cover at the handle bars. Check play when done. And a manual. Good luck.
Old Oct 27, 2010 | 06:54 PM
1flhtk4me's Avatar
1flhtk4me
Yep,those little suckers are hard to find once the bounce on the floor!
Old Oct 27, 2010 | 07:39 PM
peddler's Avatar
peddler
Just a suggestion: If you have any possible future plans that might require removing the tank again take the time now to add the Colder quick disconnect to the cross over fuel line. It's a great easy addition and it makes removing the tank a breeze. Just a suggestion.
There are other sources of quick disconnects than Colder but they do make a quality product.
Old Oct 28, 2010 | 04:11 AM
mainshaft's Avatar
mainshaft
+1 on the quick release for the tank, easy one man job after that mod.
Old Oct 28, 2010 | 07:45 AM
BigIck's Avatar
BigIck
I just replaced both cables on my '03 RKC and I did the "partial" remove of the tank and it worked fine. It is just so you can access the one adel clamp that is riveted to the frame under the tank.
morleyz
Mar 11, 2018 08:03 PM
BuckeyeUltra
May 7, 2016 06:46 PM
dhonn7
May 17, 2013 01:54 PM
bigdano
Sep 2, 2011 09:35 AM
Whiffleboy
General Topics/Tech Tips
May 8, 2006 06:16 PM
