Cams?
Old Oct 31, 2010 | 08:57 AM
dawg's Avatar
dawg
07 and up is the 96" motor with the B168 inner bearings. 99-06 used the B148's. The SE inner bearings are one and the same made by Torrington so you can get them from HD now as well.
Old Oct 31, 2010 | 02:57 PM
iclick's Avatar
iclick
Here are a couple of tutorials on changing cams on the TC96, which is the same procedure you'd use on your TC103.
Write-up 1
Write-up 2
Buy a manual, read these write-ups, and along with an inner-bearing tool and the usual items in the average tool shed you're in business. The Torrington-Timkin B-168 bearings are part #24018-10 at $15/pr.
Old Oct 31, 2010 | 07:59 PM
62hdbiker's Avatar
62hdbiker
What cams are you planning to use? I want low end torque. I am thinking SE 255's?
Old Oct 31, 2010 | 09:36 PM
tincup64's Avatar
tincup64
subscribed
Old Oct 31, 2010 | 11:41 PM
iclick's Avatar
iclick
Originally Posted by qtrracer
The inner bearings on the newer motors, they have 1" bearings, are not prone to the failures that in the older motors, they had 7/8" bearings, and even Andrews only sells the caged bearings in the 1" size not the full complement. Change the bearings yes, but to worry about whether they are the caged(Oem) style or the full comp style is kinda silly unless someone thinks they know more than Andrews.
I agree there's nothing wrong with the stock INA (caged) bearings and I've heard of no failures with these, but if you do change them you might as well install the more robust Torringtons that have double the number of needles. For only $15/pair it is good peace-of-mind, if nothing else.
Old Nov 1, 2010 | 03:22 AM
07FLHT's Avatar
07FLHT
If you want low to mid range TQ (off idle to 4,000-4,500 RPM) in a Stage 1 96" you will be hard pressed to find a better set of cams than the SE 255's!
Iron lHorse
Dec 20, 2013 04:03 AM
bigdog1949
Exhaust System Topics
Nov 19, 2013 09:51 AM
DirtyD1833
Dec 31, 2012 12:40 PM
slack20
Jan 6, 2009 01:52 PM
Ishman
Nov 13, 2007 09:36 PM
