Ok, I did a quck search and did not find my answer.
2010 UC limited when I turn the CB on it has Locked and I can not seem to find how to work it
Can someone point this dumb cracker to the right place?
Yes, some how I found the start botton
Thanks
BM
My CB box was also bad and fixed under warranty.
Be sure speaker rocker switch is all way down on back side, be sure CB is turned on, be sure the sqelch switch on left handel bar only has a few bars showing on screen, be sure com volume is turned up some ( it is separate from radio volume).
Dan
Dan
+1, read your manual, real intuitive once you figure it out
