Baffled by baffles
Old Nov 7, 2010 | 03:49 PM
dlrshort's Avatar
dlrshort
Default Baffled by baffles
What effect on power and performance do baffles have? that is, torque, hp and gas mileage? Also wondering will it affect a dyno tune enough to reprogram? Thanks.
Old Nov 7, 2010 | 08:23 PM
dlrshort's Avatar
dlrshort
someone's got to know the answer to this one.
Old Nov 7, 2010 | 10:05 PM
CT-Bagger's Avatar
CT-Bagger
It will only matter if the exhaust flow is affected. Contact the manufacturer of the pipes you are comparing and ask the tech. support people on staff.
Old Nov 7, 2010 | 11:12 PM
Lonewolf176's Avatar
Lonewolf176
A very basic explanation is how they affect backpressure. Reducing back pressure will increase top end power. Reduce it to much and you lose bottom end torque. Too little backpressure and you over scavenge the cylinder. Any time you change how the engine breaths you affect the tune.
Old Nov 8, 2010 | 09:42 PM
Phat09flhx's Avatar
Phat09flhx
The larger the diameter of the baffle the more low end you'll lose along with milage. You can just run pipes without a tuner as long as you run a stock air filter.
chaselee
Nov 25, 2016 10:36 AM
draggingframe13
Mar 22, 2013 08:12 AM
jbg
Mar 13, 2009 08:25 AM
markymark02
Exhaust System Topics
Jun 9, 2008 03:00 PM
grunt999
Dec 16, 2007 12:05 PM
