One more cam question.
Old Nov 15, 2010 | 06:23 AM
arealinvestor's Avatar
arealinvestor
Originally Posted by inverse121
Not to be a smart ***, but the Wood TW5-6 are for 07 and up motors, that's why not.
If he wanted to spend the money on a roller link conversion from Wood then he could get the TW5-6-R cams. And yes, I think its a great cam.
I know they make several different versions of the 5-6 cam.The 6 is close to the 5-6 grind too.They also make that in a few different versions!!
Old Nov 15, 2010 | 07:14 AM
STUNU's Avatar
STUNU
Thumbs up thanks
In your service manual its probably called "Clutch and Primary Drive"
thanks for the help... i may hit you up later for some help.
Old Nov 15, 2010 | 07:39 AM
inverse121's Avatar
inverse121
I am not sure what's with all the exclamation points, but its important to be very clear when posting on the forum about cams because not everyone knows what fits what. He is looking for suggestions and may assume that you are an authority on the subject.
What if he just ordered the TW5-6 for $390 at your recommendation and did not know they would not fit?
I know it sounds silly to you, but just throwing out cam numbers to someone that may not know that he would actually have to order the TW5-6-R for $450 and the $510 roller link conversion is important on a forum
I know you are trying to help. The devil is in the details on these kind of things.
Old Nov 15, 2010 | 01:21 PM
arealinvestor
Inverse,in no way was i trying to steer the guy wrong.When you order from anywhere You have to tell them what kind of bike it's going in.At that time they will tell you if it fits or not!!! He's doing research which is the right thing to do.He can call Bob Wood himself,who is a wealth of knowlegde & find out what would best for his application.When people give advice you have still do research.Every application is different.It took me 2 yrs to put together my build!!! Hundreds of hours of research to make it right, & not waste any money doing a build 2 or 3 times!!!
Old Nov 16, 2010 | 10:54 AM
STUNU's Avatar
STUNU
guys i wasnt trying to get anybody in a debate or arguement over this just trying to gather intel, all the advice i get i investigate im a procrastinater and like to plan everthing out so im not stuck in my garage with my thumb up my u know what thinking what do i do now...im always looking out for murphys law.
Old Nov 16, 2010 | 12:00 PM
FLHTCU Owner's Avatar
FLHTCU Owner
Originally Posted by petemac
Oh yeah, I run the Andrews 26 and love them.
Old Nov 16, 2010 | 12:23 PM
djl's Avatar
djl
Originally Posted by boogaloodude
Andrews 21 or 26. I think I'd go with the 21 but either one would work for you.
inverse is also right about the devil being in the details when you order cams. There are several different configurations; one for your stock 88" (will also fit with the SE Hybrid cam plate conversion kit), one to convert the stock 88" to '07 the OEM cam plate conversion and one for the stock 96" setup. Additionally, each cam manufacturer has different designations for those different configurations. For instance, the Andrews 37, a very popular cam, is available as a TW37b ('99-'06 chain drive) 37G ('99-'06 gear drive), 37N (converson for '99-'06 upgrade to '07-'11 chain drive) and 37H ('07-'11 chain drive).
You won't have any problem ordering cams for your applicaiton but the point inverse121 made is a valid one.
Old Nov 16, 2010 | 02:36 PM
STUNU's Avatar
STUNU
Thanks djl
Old Dec 4, 2010 | 04:34 PM
STUNU's Avatar
STUNU
Default clutch basket
Any reason you are yelling at me?
Did you want me to do it for you?
24 tooth motor sprocket 40269-85a
37 tooth clutch basket 37846-99a
use you stock chain and tensioner
procedure is covered in your service manual
hey inverse121 do the 24 tooth sprocket and the 37 tooth clutch basket fit something else im having trouble locateing them on ebay....
Old Dec 4, 2010 | 05:01 PM
inverse121's Avatar
inverse121
You are looking for a setup from a 99-01 fuel injected touring bike.
Here is a used one, you would probably want to know how many miles are on it and you will still be taking some chances.
http://cgi.ebay.com/ebaymotors/99-Ha...item483de5203f
Here is clutch basket
http://cgi.ebay.com/ebaymotors/CLUTC...item1c175ce192
Here is a compensator sprocket
http://cgi.ebay.com/ebaymotors/HD-HA...Q5fAccessories
