Air ride installed...
Old Mar 4, 2011 | 09:41 PM
  #81
Cousy's Avatar
Cousy
This is my next project. I already have my switch pre-wired, I just need compressor, solenoid, lines, fittings, and shocks. I am not sure what to do about the bushings in the shocks though. I have zero knowledge about this type of modification and am not sure where to get the bushings or where to start. Could anyone give me some tips with getting the shocks ready for mounting?
Old Mar 4, 2011 | 09:52 PM
  #82
Pc PaiN's Avatar
Pc PaiN
I went with energy suspension for the bushings and had to take my dremel to them to make them fit correctly. Called energy suspension to make sure that was fine and they said to saw, grind, slice those bushings and they would be fine.
Old Mar 4, 2011 | 10:34 PM
  #83
gwphelpss10's Avatar
gwphelpss10
You should be able to find the bushings that you need at any industrial supply store. That is where I got mine. It rides so much better than stock. Or at least I think so.
Old Mar 6, 2011 | 05:46 AM
  #84
Drtumolo's Avatar
Drtumolo
ok I am finally going to do this install. I have the shocks and solenoid, where did everyone get there compressor, what one did you use and how did you mount it?
Thanks
Old Mar 6, 2011 | 06:43 AM
  #85
shortride's Avatar
shortride
Great looking bike but I want to see you it go up.
Old Mar 6, 2011 | 07:17 PM
  #86
Cousy's Avatar
Cousy
Is there any chance that someone could tell me the exact pieces that I need from a place like Energy? I have a feeling that if I call and tell them I need lower shock bushings for a Harley Touring bike that will fit Monroe MA785 Corvette shocks I may not get very far. But for all I know, they may know exactly what I need from that information. Thanks for the help, guys.
Old Mar 7, 2011 | 09:35 AM
  #87
Drtumolo's Avatar
Drtumolo
Is every one getting there compressor from arnott and are you using their mounting bracket?
Old Mar 7, 2011 | 09:15 PM
  #88
Pc PaiN's Avatar
Pc PaiN
I used 9.9105G bushings on my 2010
Old Mar 9, 2011 | 10:24 PM
  #89
gwphelpss10
I got my compressor from arnott's. on my 2010 SG I was ableto mount everything in the tray on the right side where the ABS module would go.
Old Mar 10, 2011 | 12:24 AM
  #90
JohnCA58's Avatar
JohnCA58
I get my compressors from Rocky Mountian Suspension, Arnott uses Viair compressor, the model I use has a mounting base 098C here is a link.
http://www.rockymountainsusp.com/Via...s_90Series.htm
