Road glide Fairing 09/10 ????
Old Nov 19, 2010 | 09:00 PM
mikeboztx's Avatar
mikeboztx
Default Road glide Fairing 09/10 ????
Anyone know what parts I need to change to mount an 09 fairing like a 10 so I can use the vented lowers like the ones on the new RG Ultra? It looks like the 2 chrome mounts at the engine crash bar, and the big square mount with the 4 studs that goes thru inner fairing. Not sure if that all.
Mike
Old Nov 19, 2010 | 10:08 PM
DTTJGlide's Avatar
DTTJGlide
That should be it, bracket 58530-10 is about $50 from Zanotti, I think the chrome brackets are about $50 each if you use the screws & clamp halves that you already have. It's pretty straight forward, you have to remove the tank & the fairing, that's about it. Another good point is that it raises the windshield about an inch.
Old Nov 19, 2010 | 10:41 PM
Jags93's Avatar
Jags93
yes that is all you need. The new fairing mount is part# 58530-10 and goes for $49.63 at Zanotti's.
chrome lower mounts are part#s 58454-10 and 58460-10 for $32.54
I am just about to do this very job. just ordered the parts myself. The only thing I need to figure out is if you really need the $75 HD tool to remove the ignition switch connector. You do not need to remove the tank - just the inner/outer fairing, the lower nacelle covers (maybe) and unplug a bunch of wires.
Old Nov 20, 2010 | 08:38 AM
robertg's Avatar
robertg
Does it actually raise the fairing? I thought it just tilts it so the back is higher and the front is lower?
Old Nov 20, 2010 | 09:22 PM
mikeboztx's Avatar
mikeboztx
Not sure what it does, but its lets you use the vented lowers. I ordered parts today from LSHD1. Thanks for part #'s I hope that is all I need.
Mike
Old Nov 20, 2010 | 09:37 PM
METALKAT's Avatar
METALKAT
You don't need the ignition tool, here's a video of how to take it apart and make your own tool. Works awesome!
https://www.hdforums.com/forum/touri...h-removal.html
Hats off to CLL375 for making the video.
Old Nov 22, 2010 | 06:51 AM
Jags93's Avatar
Jags93
The mounts raise the fairing and tilt it forward 2 degrees.
METALKAT,
I am talking about the tool for the wire connector that goes in the front/underside of the ignition switch, not the switch itself.
Old Nov 22, 2010 | 10:33 AM
METALKAT's Avatar
METALKAT
Sorry about that my bad, I believe a long skinny flat blade screw driver will do it. Kinda tricky but only took a minute.
Old Nov 22, 2010 | 11:27 AM
Jags93's Avatar
Jags93
Awesome thanks.
If all goes to plan I'll begin tearing mine down tonight. I'm going to order the lowers Zanotti's. I already have the mounts.
One excellent tip I got from the this forum - remove the headlight assembly before re-attaching the fairing. That way you can see the hooks and line the fairing up very quickly. The headlight just snaps in right after that.
Old Nov 22, 2010 | 11:31 AM
Jags93's Avatar
Jags93
Yeah I'll be doing a bunch of cleaning as well!
