Removing gauges from fairing???
Old Nov 22, 2010 | 12:26 AM
brino's Avatar
brino
Default Removing gauges from fairing???
Can someone tell me how the gauges are removed from the fairing? I'm looking to tear it down to paint.
Old Nov 22, 2010 | 12:42 AM
mtclassic's Avatar
mtclassic
It is easy. once you get the fairing off it is pretty self explainitory. when I did mine I color coded the connections but really they can only go in one way. I found it was easier to remove the gauges after the inner fairing was removed and easier to install the gauges back in the inner fairing before installing it.
Old Nov 22, 2010 | 10:14 AM
brino's Avatar
brino
Thanks
Old Nov 22, 2010 | 10:47 AM
vzts4q's Avatar
vzts4q
Default gauge removal
1. Buy service manual
2. Read service manual section relating to the faring
3. It is really not that hard after the outer faring is removed, the gauges are the easiest pieces to get out! (2 nuts. and the wiring connectors on each gauge) There are far more complicated things that need to be removed. For example to remove the lower faring cap the ignition switch needs to be removed this is where the majority of people run into problems. It comes out easy but sometimes going back is VERY difficult.
Old Nov 22, 2010 | 10:59 AM
slothy's Avatar
slothy
ya just did mine, just remove plugs, and remove the little nuts and they slide out from the front.
Old Nov 22, 2010 | 11:14 AM
IBHarley's Avatar
IBHarley
main gauges have 2 scews remove push gauge out towards rider smaller ones have the 2 nuts putting back they have a notch in the ring to line them up very easy job
Old Nov 22, 2010 | 11:31 AM
BadBagger08's Avatar
BadBagger08
I just finished putting mine back together. Make sure you label the wires to the gauges as the can plug into any gauge. I also switched the tach and speedo location as I was always watching the speedo as the tach when beating on my bike. most cars are on the left.
I also painted my uppers and the chrome plate under the fairing. pics in my garage. Now I need chrome lowers I will be going with Arlen Ness Hot Legs
threads that will help
https://www.hdforums.com/forum/touri...ep-w-pics.html
https://www.hdforums.com/forum/touri...h-removal.html
GL
bbissell
2014-2024 Touring Models
11
Feb 15, 2022 11:37 AM
mavantix
Jul 24, 2015 06:30 PM
Defy
Nov 27, 2010 01:11 PM
brihvac
Sep 18, 2008 04:28 PM
bigbean78
Nov 13, 2007 10:01 AM
