cam timing off. need help please
As far as the 103 or 107 kit... Do it yourself. Like you said, the learning process along with the satisfaction you'll get by doing it yourself will be worth it. If you can make it through a cam change you can certainly make it through a jugs/piston change.
Same for whatever tuner you decide on. These autotune set-ups available now make tuning so much easier. Just get one with the wideband sensors and autotune feature and you can dial it in yourself pretty darn close. A dyno may get you a little more on a chart but I doubt if the seat of your pants will feel the difference. Remember, this is a street bike, not a race machine, so you don't need every last ounce of torque/horsepower.
He'll need to check ring gap, get the rings in correct alignment, yada yada....
I'm from Nashville and if he can hold off until January, I'd be glad to help him.
A dealer won't allow him to stand there and watch, to learn...and I'd be surprised if FuelMoto would, either.
I might be wrong but I think I read in the 107 thread by Fuelmoto that they do everything for you as for ring gap and such. I am sure they can move if you mess with them but from what I understand Jamie sends this kit out ready for install. I think I also read that there was no need for a ring compressor. If Jamie sees this I am sure he will pipe in and correct me.
(Assuming you have installed the cams correctly, of course.)
Rotate the wheel (which rotates the engine), while holding your finger on top of the intake lifter. When the intake lifter raises, that piston is on the intake stroke. Once the intake lifter drops and then bottoms out, and the piston is on the way up again, that is the compression stroke. Put your finger over the spark plug hole, and you will feel the air pushing against your finger. Place a long drinking straw in the spark plug hole, BE CAREFUL NOT TO LET IT SLIP ALL THE WAY INSIDE! With the piston on the compression stroke, it will push the straw up. When the straw stops moving up, the piston is at Top Dead Center (TDC). You may go a little passed TDC (the straw will begin to drop), but you can rotate the engine back and then forward again to get it correct. Feel the lifters again, to be sure they are both down, and level with each other. This is the beginning of the power stroke of the cylinder, and the lifters should be on the base circle of the cams which is where you need to be at to adjust the push rods OF THAT CYLINDER. You can go a little further than TDC, since the valves/lifters should not start to raise again until the exhaust stroke begins. Once you have installed one set of pushrods, let it set for (manual says 10 minutes but I like 30 minutes at least). THEN move to the next cylinder, and follow the same directions for it...
I think some one said you could turn the engine backwards... (Might have been in another thread I just read tho)
You can, but this will introduce slack to the wrong side of the cam chains, which is not putting the cams in the correct position. I always like to back off enuff (if I have to), and then roll forward again, to keep slack in the cam chain on the correct side. (Of course, if yer runnin geared cams this is a moot point!)
I am finally putting it back together. I put all 4 adjustable pushrods in and waited for them to bleed down and the first one I did (rear cylinder intake) will not turn freely. I haven't seen on any of the threads how to fix this. Do I just redo that cylinder or is there another trick to fixing it?
Thanks in advance.
Thanks in advance.
Remember earlier posts... Each individual cam lobe must be on it's base circle when you adjust the corresponding pushrod. You'll need to rotate the engine to do this. You can't just adjust all the pushrods at one time.
