Is it safe????
Old Nov 29, 2010 | 06:28 AM
2008FLHP's Avatar
2008FLHP
Default Is it safe????
No not going to the dentist but, putting these 13 1/2 shocks on my 08 RK? I put some 12" on and I sometimes bottom out 2up.
HD part #54726-00 (see link below)
http://cgi.ebay.com/ebaymotors/ws/eB...CA:MOTORS:1123
Thanks and ride safe!!!
Old Nov 29, 2010 | 09:38 AM
jjnoble's Avatar
jjnoble
Default Is it Safe
Is it safe
dentist
Marathon Man with Dustin Hoffman?
Old Nov 29, 2010 | 10:23 AM
mkguitar's Avatar
mkguitar
Those shocks are usually mounted on MUCH lighter weight bikes such as dynas and sportys.
Have you tried the stock height air shocks, that would have come on your bike new?
Add air for more carrying capacity- subtract air for smoother ride.
or there are plenty of performance shocks which have the capacity for the Road king
IF the front end of the bike has been lowered you would have to restore it to stock height or you could have a dangerous handling situation
Bottoming out can result in the tire tearing up your rear signal light wiring, tire damage ( grooving from the seat mount nut) etc.
mk
Old Nov 29, 2010 | 05:52 PM
smokindave's Avatar
smokindave
The 12" shorter shocks can go up to 50lbs air. What pressure do you have yours set at?
Old Nov 29, 2010 | 08:10 PM
skratch's Avatar
skratch
if you only bottom out sometimes on the 12" shocks, why don't you go back to the original 13" air shocks? or did you get rid of them?
Old Nov 30, 2010 | 04:13 PM
Ricor Shocks's Avatar
Ricor Shocks
Former Sponsor
Like it was said earlier they look like Dyna or sporty shocks.
If they are Dyna's they will be WAY too stiff. Sportys are closer in spring rate and valving but they are a little softer and the eye to eye collapsed length is less so you will probably bottom out on something else on your bike besides the shocks. I.E. tire hitting the fender etc...
Brian
6 gun
Jun 5, 2018 03:17 PM
LeonidasIssopoulos
Nov 10, 2013 01:22 PM
RaceFace
Feb 4, 2013 06:29 AM
blarg
Jun 19, 2012 03:07 PM
jag1886
Oct 29, 2007 07:17 PM
