what is ?
Old Nov 29, 2010 | 07:39 PM
onaride63's Avatar
onaride63
Default what is ?
What is considered a large displacement engine?
the reason I ask is that I just did a static compression test and I'm at 171 front jug and 174 on the back. From what i read on andrews site I might have some pinging issues with that compression ( on a large displacement motor ). My motor is a 95''. what do ya think ?
Old Nov 29, 2010 | 08:50 PM
Gruamach's Avatar
Gruamach
I could be totally wrong, but from what I've read/heard, "big bore" is 105+ CI.
I've also heard the 103 kit referred to as a big bore as well, but I've seen the impression of that being the top end of the "not big bore" more so.
Old Nov 29, 2010 | 09:13 PM
bagger76's Avatar
bagger76
This is hard to answer to many variables.They tell me that 9-1 up to 9.5-1 will work great and your cam has alot to do with corrected compression static will be higher and those numbers to me look ok maybe low.I have around 9.3-1 corrected compression and 187 lb of cranking compression in a 103".Check out this site and go to twin cam them calculators. just put in some numbers to get ideas. bigboyzheadporting
Old Nov 30, 2010 | 08:21 AM
onaride63's Avatar
onaride63
Thanks ! I went to the bigboyz site and went through the calculator. I got a cold crank at 168 ( close to actual test ) at 7000'. My corrected compression is 9.94.1. But at sea level the cold crank goes up to 210. I do have compression relieses but will I have performance problems when I leave my high country for the coast ?
DBLX
Apr 20, 2016 09:13 AM
Cloyder
Engine Mechanical Topics
Oct 14, 2013 08:57 AM
James Butler
EVO
Aug 1, 2010 12:21 AM
markymark02
May 21, 2008 05:02 PM
byersmtrco
Apr 23, 2008 09:50 AM
