Louder exhaust question
Old Nov 29, 2010 | 11:29 PM
#1rocketman's Avatar
#1rocketman
Default Louder exhaust question
Ok you guys,I've read tons of posts in here about true duals,baffles,drilling baffles out,removing baffles,etc.etc.etc. I have a 98 Road King Classic with Vance n Hines fishtails.I know what i want/need...true duals and a tuner,problem is,I just cant afford to do both right now and it requires both. After reading some guy's post tonite,got me thinking about something.Tell me if this is crazy/wrong/stupid or whatever.There is very little exhaust that exits out the left muffler,what if I removed the baffle in the left muffler?
Old Nov 29, 2010 | 11:48 PM
user 8373900's Avatar
user 8373900
You would be better off to plug the crossover to the right side in the Y pipe. (poor man's true dual).
Mark
Old Nov 30, 2010 | 09:01 AM
head's Avatar
head
you will lose some bottom end torque with the true duals without a doubt. the exhaust will also be louder.
head
Old Nov 30, 2010 | 09:27 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Try and plugging the crossover sounds like your first option.
Old Nov 30, 2010 | 11:10 AM
nutsandbolts5212's Avatar
nutsandbolts5212
Just remove the exhuast all together, that should do the trick!
Old Nov 30, 2010 | 11:35 AM
Rush Racing Products's Avatar
about 80% of the exhaust goes out the right side, with stock head pipes. If you block off the left side muffer, you will keep the sound but performance should increase (fake 2 into 1). A lot of people with Rush would put a 1.75" baffle in the left and 2.25" on the right. By using a smaller baffle it almost completly forced all exhuast out the right side and caused drastic performance increases due to the added back pressure. I would assume removing the left baffle will have opposite effects. It might balance the sound but torque will go down as well.
Ryan
Old Nov 30, 2010 | 11:48 AM
harleyflhrs's Avatar
harleyflhrs
Default plug crossover
pluging crossover works there is no loss of low end torque due to u are still have stock dia. header pipes 1 5/8". so u need 1 5/8 " frost plug,tig weld in on angle for flow. u now have a better sound and duals. only thing for bikes after 2006 one must move o2 senor from crossover to left exhaust pipe same distance as was on crossover from head.
Old Nov 30, 2010 | 12:34 PM
#1rocketman
Yeah I tried that but kept catching my girlfriends jeans on fire!
Old Nov 30, 2010 | 12:42 PM
#1rocketman
Thanks guys....I've read about plugging the crossover and the Fullsac kit. Guess I'll do a little more reading. Unless......any of you wanna throw about $700 bucs my way!
Although Fullsac says no efi remapping required. Maybe someone can set me straight on that subject??
cajun1957a
Jun 19, 2016 03:03 PM
ridedaddy
Jul 16, 2014 09:28 PM
Road Hawg
May 2, 2012 08:31 AM
thumperhumper
Mar 8, 2009 05:58 PM
