Battery Tender ?
Old Dec 15, 2010 | 09:20 AM
  #31
Woodchuck's Avatar
Woodchuck
Originally Posted by Port Dawg
Hmmm..guess I better get my pig tail for my Battery Tender Jr installed lol......correct me if I'm wrong but to install the pigtail it just goes on the battery posts right?.....What is the order so I don't blow myself up? lol
1. Put some electrical tape around the negative connector so it doesn't inadvertently touch some metal and ground while you're attaching the positive connector of the pigtail.
2. Connect the positive end of the pigtail to the battery first.
3. Remove the tape from the negative connector.
4. Connect the negative end of the pigtail to the battery last.
5. Run tepid water over hands to treat the frostbite.
But it probably doesn't make much difference since the battery is likely dead as a doornail from sitting in the cold with the security system trickle discharging it. JUST KIDDING
Old Dec 15, 2010 | 09:22 AM
  #32
pargenz's Avatar
pargenz
Originally Posted by webbug
Whats the difference between the battery tender and Harley Davidson Charger?
Probably a hundred dollars...
Old Dec 15, 2010 | 09:30 AM
  #33
rebel97's Avatar
rebel97
I bought a tender from HD for around 50.00. Sevice dept says to leave it plugged up year round and it will extend your battery life.
Old Dec 15, 2010 | 09:56 AM
  #34
METALKAT's Avatar
METALKAT
Call me crazy but I don't like leaving any charger/tender pluged in while I'm not around. Cordless drill, flashlights, batteries, etc...
I'm in my shop/shed almost every day, when I turn the lights on I power up my chargers too. I just don't feel comfortable leaving 110v plugged into a charger leading to a battery. Anything could happen between these 3 points of contact, although the stats are in your favor I just choose not to chance it.
Maybe its not the best solution for my tender and battery but I have had bikes all my life and I rarely have to buy a battery. Sure, maybe I have to buy a battery or tender a couple years sooner but the cost is worth my piece of mind.
Ride Safe
or in this case Charge Safe
Old Dec 15, 2010 | 11:01 AM
  #35
dwayne.aycock's Avatar
dwayne.aycock
The tender is the way to go, especially if your bike has a security system. The security system will drain the battery over time. Your battery and charging system need to know what a full charge from the battery is. I leave mine plugged in all time time when I know I will not be riding for several weeks. The charger sends a charge to the battery when it senses a drop in the full charge. Once it is back up to full charge, the tender goes into idle mode.
Dwayne
Old Dec 15, 2010 | 12:57 PM
  #36
SecondChance!!'s Avatar
SecondChance!!
Plugged in all time when not riding. Alarm on when I walk away, no matter!!!! Even when in house garage. If I am not going to be riding for a day or 2, disc lock as well. Paranoid?!?!?! No, crooks and thieves are what keep me employed!!!!
Old Dec 15, 2010 | 01:10 PM
  #37
Firetender's Avatar
Firetender
Schumacher makes the maintainer that WalMart sells for around $15. I have at least three of these things around the garage - there is really no reason to spend more money on a battery maintainer unless you also need a T-shirt to go with it! A chemist's point of view: Think of a battery as a box of energy, if you keep it full, it will stay full longer than if you take some out and replace it. You only get so much lead/acid turnover until the lead is gone, you can't get 12V anymore and you need to buy a new battery. Keep your maintainer plugged in 24/7 and you'll get more life out of your battery because you spent less lead replacing it to re-charge it.
Old Dec 15, 2010 | 01:13 PM
  #38
shore's Avatar
shore
Ride Safe
That's fine but it has an inline fuse for such mistakes. It's really made to leave plugged in.
Old Dec 15, 2010 | 01:18 PM
  #39
Avalanche_Mutt's Avatar
Avalanche_Mutt
Bought one last night was $19.95 from Walmart like this Schumacher
Old Dec 15, 2010 | 01:32 PM
  #40
pt4u2nv's Avatar
pt4u2nv
Originally Posted by shore
Lol, no.
Tenders are smart charges and a fully charged battery lasts longer than a warm drained battery.
The tender is not going to burn out.
i agree.....I have a spare battery that has been on a tender solid for over a year and is still in fantastic shape. A tender is just what it says....a tender....only charges when battery hits about 80 % ... other than that it only maintains the charge as necessary. It will not burn up....
