TVIII Owners, does your system backfire?
Old Sep 27, 2006 | 03:48 PM
Szmytty's Avatar
Szmytty
Default TVIII Owners, does your system backfire?
So, I finally did my TVIII upgrade on my 06 SG to work with the new Rineharts. Here is what I used:
Terry Components TVIII
SE Air Cleaner
True Duals RineHarts with O2 sensor
Torque Cones
The bike runs awesome with no need for a Dyno Tune. The only thing that bothers me is the backfires on decel. My 78 does the same thing, but I'd expect that from a 93" Shovel with Drag Pipes. I did not do the Stage 2 ECM Upgrade yet. I will do that when I get the Steering Lock fixed. Anyone else have any comments or similar experiences?
Thanks
01 Suzuki Hayabusa
78 FLH with 93" Stroker
06 Street Glide with True Duels\TVIII
Old Sep 27, 2006 | 04:58 PM
bountyhunter's Avatar
bountyhunter
Default RE: TVIII Owners, does your system backfire?
Sure ya got all the wires spliced correctly?
Old Sep 27, 2006 | 05:06 PM
gunrunner's Avatar
gunrunner
If the system can be programed like a PCIII, then you can add a 15 value to the 0% range from 1500 rpm on up and it will cure your decell poping, leave below 1500 rpm alone or ideling problems can occur.
Old Sep 28, 2006 | 09:33 AM
joeschmoe's Avatar
joeschmoe
I am running the same basic set up as you. SE Air Cleaner, Bub True Duals with Fullsac recored slip ons....I have had my TVII for 6 months now and mine is fine! No coughing on decel, no backfiring, nothing but smooth throttle response!!!!
Like Bountyhunter suggested
Old Apr 12, 2007 | 06:48 PM
Szmytty's Avatar
Szmytty
Just a update. I did not have the ECM Stage 1 download. I finally got the update and the decel backfiring went away. I also got a new voltage regulator as part of a recall. Could have been either I guess.
Thanks
Old Apr 13, 2007 | 02:56 PM
RedBarron59's Avatar
RedBarron59
ORIGINAL: Szmytty
SE Air Cleaner
Torque Cones
Thanks
01 Suzuki Hayabusa
Is this a Terminal Velocity III with dual O2 sensors?
anonymous_1
Sep 5, 2013 12:38 AM
shore
May 4, 2013 12:29 PM
06 Road Glider
Feb 24, 2012 07:55 AM
sbl1985
Jul 31, 2007 06:04 PM
GOSTAZ
Jan 21, 2006 08:10 PM
