need help with dyno 2011 110ci performance
Old Dec 19, 2010 | 01:27 PM
cupidltp112's Avatar
cupidltp112
Default need help with dyno 2011 110ci performance
i have a 2011 street glide with a 96ci that i upgraded with a 110 kit from the 2011 screamin eagle catalog. while doing the upgrade i had the dealer switch the cams to se 259e cams with se perfect fit push rods, went with the se high compression pistons 10.5:1, se lefty bearing on both sides of the case, se high performance inner cam bearings, se heavy breather air cleaner, se touring oil cooler, se super pro tuner, se performance clutch disc with heavy duty spring, bike already came with se compensator, heads are stock se cvo 110 heads, and i had them install rinehart true dual exhaust. what kind of hp/torque numbers should i expect to see on a dyno with all the upgrades that ive done to the bike. i did a 500 mile break in and had the bike dynoed at a local harley dealer. in my opinion i dont believe the bike was tuned properly. i was told the bike put out a max of 101.8 hp and 105 torque. are these numbers what i should expect with this setup or am i right to think that the bike was not tuned properly. what numbers should i be putting down with my setup. any feedback will be greatly appreciated. thank you
Old Dec 19, 2010 | 01:36 PM
Mike's Avatar
Mike
Post the dyno chart. No way to tell from the info you've posted. I'd expect higher numbers, but I don't put too much into dyno numbers anyway. I'd be more interested in seeing the overall shapes of the torque/hp curves and the afr chart. How does the bike ride? Are there any issues that show up while riding?
Old Dec 19, 2010 | 01:47 PM
cupidltp112
all i was given was a dyno chart with hp readings and it shows max hp at 101.19 at 120mph. it shows a steady increase at 70mph and up. the bike has some popping and ran a little rough on decel
Old Dec 19, 2010 | 01:48 PM
shore's Avatar
shore
Numbers are only relative but it sounds like it needs a good tune. No need to pop decel if done right and certainly not a rough idle.
Old Dec 19, 2010 | 01:56 PM
Kevin's_09FXDF's Avatar
Kevin's_09FXDF
Put a 2-1 and youd pick up a few, those numbers seem low but idk... The poping at decel may be just your choppy cam, id say post the graph so we can see the curve.
Get a 2-1 and a retune id say may be a different tuner
flashracer
Jan 25, 2014 12:01 AM
cupidltp112
Screamin Eagle CVO Models
Dec 19, 2010 11:32 PM
cupidltp112
Dec 19, 2010 07:56 PM
cupidltp112
Dec 19, 2010 05:52 PM
cupidltp112
Dec 19, 2010 06:07 AM
