Picky Picky
Old Dec 27, 2010 | 03:04 AM
Lonewolf176's Avatar
Lonewolf176
Originally Posted by mike5511
You're right, bet that doesn't end the conversation however. After all, who knows best, the construction worker who buys one, or the engineer who designed it?
How about a data log that shows the ecm remembers 7.7% TPS% @ 0 rpm from a TBW bike that has been using the kill switch to shut off the bike? The reading should be 5%, which is what the ecm actually uses for 0. It also shows a higher TPS voltage than it should.
Old Dec 27, 2010 | 04:18 AM
Bait56's Avatar
Bait56
Ignition Switch.
Old Dec 27, 2010 | 05:04 AM
Jinks's Avatar
Jinks
Originally Posted by Valkyrie
Hello & Merry Christmas & Happy New Year
I have a small question and need imput.
Do you shut your engine down by using the switch at your thumb? or do you use the larger on/off where the key is inserted. Ultra Classic 08. I was told by two different dealers that there was a proper way and it made a difference in the life span of said switch
Thanks
If (& I doubt it) those dealers were right, my FXR is the right way. I've used the ignition switch since it was new & both switches are original. Of course if you need more than 24 years out of a switch you might want to try something different............
Old Dec 27, 2010 | 06:22 AM
mainshaft's Avatar
mainshaft
Always ign switch
Old Dec 27, 2010 | 06:36 AM
Steel Billet's Avatar
Steel Billet
Ingition switch, I never have used the kill switch.
Old Dec 27, 2010 | 06:39 AM
dog155's Avatar
dog155
Have always used the Ignition switch that is what it is for.
Old Dec 27, 2010 | 07:50 AM
piasspj's Avatar
piasspj
Originally Posted by 1931jamesw
I have been using the kill switch because that's what I used on my carbed bike, however, I have read where you should not do that with a fuel injected bike. The reason given was that the weight of your hand on the throttle, even just slightly can keep the throttle open very slightly and after doing it several times, the ECM "learns" that the slight opening is the closed throttle position when actually it isn't. Over time it causes an increased idle speed. I'm now trying to get in the habit of using the key ignition switch using my right hand so I have to take my hand completely off the throttle to shut the bike off.
I thought that was only an issue on the '08s with TBW, have you tried it on your '09?
I almost always use the thumb switch, even on my '08. Keeps it clean and also makes it my first move in an emergency (all modern production bikes have the kill switch at that location).
Old Dec 27, 2010 | 07:56 AM
BuzzHD's Avatar
BuzzHD
than whats the kill switch for
Old Dec 27, 2010 | 08:02 AM
Iceman24's Avatar
Iceman24
Engine (kill) switch...read about it in your owner's manual.
Old Dec 27, 2010 | 08:08 AM
DocHarley's Avatar
DocHarley
I dump the clutch to stop the engine then shut off the kill switch then shut off the ign then put down my kickstand. I was told never put down the kickstand first because tilting the bike before killing the engine using the kill switch will cause oil to build up in the combustion chambers and then bend my rods when I start my bike. This is how the dealer told me to do it. :/ WTF
