compression test 113"
Old Jan 3, 2011 | 08:42 PM
harleycharlie1992's Avatar
harleycharlie1992
Unofficial HDF Chaplain
if you lost oil pressure, (oil loss) I would be very concerned with scored cyl walls, You need to inspect visually, sounds like you're gonna anyhow, cuz I think that motor is coming all apart
Old Jan 3, 2011 | 08:50 PM
1931jamesw's Avatar
1931jamesw
I'd really like to know where that oil went... if it was ever put in.
Old Jan 3, 2011 | 09:05 PM
Biggzed's Avatar
Biggzed
Originally Posted by creep1
ok just finished comp test. front cylinder read 200psi through 5 cranks. rear cylinder first and second crank read 210psi then as battery startted to die dropped to 200psi. front plug was clean, rear plug had a lilttle oil on it. So where am I at right now?
You probably ruled out a major problem related to rings. Cylinder pressure is good. You should be making some serious torque with that. Still curious how those cylinder walls look. Have them checked for roundness (you'll need to have that done using torque plates). Then check piston to cylinder fit. I would look to send them to JD's Cycle or one of the other good shops in your neck of the woods.
Keep posting up what you find.
Zach
harleycharlie1992
how far did ya go after service?
Old Jan 3, 2011 | 09:07 PM
1931jamesw's Avatar
1931jamesw
If I remember correctly, about 200 miles after build.
Old Jan 3, 2011 | 09:25 PM
creep1's Avatar
creep1
Yeah at this point im guessing oil was never put in. couple hundred miles easy after completion. builder said cylinder walls def has wear. gonna send them out to have them honed and pistons fitted. Larrys machining in chicago is probably gponna get my heads to rework valve-train so prob just send cylinders there too
Old Jan 3, 2011 | 09:26 PM
creep1's Avatar
creep1
wheres jd's cycle at ?
Old Jan 3, 2011 | 11:41 PM
Biggzed's Avatar
Biggzed
Bethlehem, PA. Actually the more I think of it, I'm pretty sure they are primarily a tuning shop. I think they send their machine work to Hillside.
Hillside Motorcycle & Machine
5225 South Main Street
Munnsville, NY 13409
Phone/FAX: (315) 495-6650
Zach
Old Jan 4, 2011 | 07:55 AM
creep1's Avatar
creep1
hows JD's for tuning ? What about hillside? gonna need a good tuner once this things back together. need someone a reasonable distance from nyc
Old Jan 4, 2011 | 05:02 PM
Biggzed's Avatar
Biggzed
JD's has a very good reputation for tuning. Not sure where in NYC you are, but it's about 90 miles from the NYC side of the Verrazano bridge.
Zach
djs
Milwaukee Eight (M8)
32
Nov 27, 2021 05:30 PM
hdrider53
Exhaust System Topics
Nov 10, 2021 07:27 AM
CanadianHD
Mar 8, 2018 07:44 AM
robbyville
Engine Mechanical Topics
17
Sep 16, 2017 11:28 AM
txphatboy
Mar 4, 2013 02:28 PM
