What will i need to install these bars
Old Jan 1, 2011 | 06:08 PM
STUNU's Avatar
STUNU
Default What will i need to install these bars
hey guys i want to put these bars on my 06 flhr, i have heritage bars on there now but i need something a little higher. wo614 outlawz are what they are called. any body know exactly what ill need to install ? longer cables? wire extensions? ant help would be great.
Old Jan 1, 2011 | 06:13 PM
Garcou's Avatar
Garcou
Patience! Probably longer clutch, and break maybe some wire extensions
Old Jan 1, 2011 | 06:44 PM
heavyhitter01's Avatar
heavyhitter01
I would suggest riser bushings too. Best thing you can do is just get with Dr. V-twin he will set you up with everything you need and for a good price.
Old Jan 1, 2011 | 08:16 PM
silverbullitt's Avatar
silverbullitt
How tall are they? I can tell you everything you need if I know the size.
Old Jan 1, 2011 | 09:06 PM
Texas Rapier's Avatar
Texas Rapier
The 614's are 14 inches
Old Jan 1, 2011 | 09:15 PM
Texas Rapier
Being that your is an 2006 you will need:
+8 throttle and idle cables.
+8 Clutch cable
+8 Upper modular brake line
STD lower Modular duel disc brake line
Wire extension kit
Poly handlebar bushings
Handlebar 1 peice clamp
Hopefully Silverbullit can confirm this. just my guess
Old Jan 1, 2011 | 09:42 PM
silverbullitt
Exactly. +6 for 12's, +8 for 14's. And he mentioned the clamp too!
Old Jan 1, 2011 | 10:07 PM
sifularson's Avatar
sifularson
I have the 12" outlawz on my bike. I changed all the cables and ran the wiring internal because I wanted steel braided cable and brake line. The wiring was long enough and didn't require cutting and soldering. Some guys got by without have to change the clutch cable and brake line on the 12s but I think you'll need to on the 14s.
BTW, these bars have a 90 degree corner at the bottom which makes it difficult to get the wiring through. Just a warning.
Old Jan 1, 2011 | 10:18 PM
Texas Rapier
I read somewhere that the pre 2008 bikes had two seperate riser clamps and that they did not have the clamping force required for taller bars. so the top clamps have to be replaced with a one peice top clamp.
The 08 and later touring bikes have a factory one peice top clamp.
The bushing on all years need to be replaced with polyurathane heavy duty bushings to reduce the handle bar movement of the taller bars.
I'm Getting ready to install a set of Wildones 502's so I've been doing a lot of research, :~)
Old Jan 2, 2011 | 10:21 AM
STUNU's Avatar
STUNU
thank you guys for all your help. i didnt realize that i would need so much, but i want it right. i thought bars clamp and maybe clutch cable boy i was mistaken. that is why i like this forum. you guys know everthing the rest of us need to learn. thanks again.
THE BARS ARE ABOUT 224.00 SO ANYBODY KNOW HOW MUCH FOR THE REST, I WILL DO THE WORK MYSELF.
