Windshields
Old Jan 4, 2011 | 10:53 PM
  #41
V2Evo96's Avatar
V2Evo96
Originally Posted by grandpatim
The one that came on my 01 is about 2 inches above my line of sight if I sit up and not slouch. I measured it from the trim to the top and it measures 12 or 13 inches. It's probably the original one cause it has scratch swirls and rock dings. I want to replace it and been reading all the threads in the search function. I get a lot of turbulence with this one in my face and it drys my contacts out and after about 40 or 50 miles I get to where I almost can't see. I don't get any head buffeting though and my wife says she is pretty much out of the wind with it. But I want to look over the windhsield but I don't want to mess with her ride either. I'm 5'9" and I thinking about going with an 8" flip up. We both also wear half helmets cause we both get too hot in a 3/4 or full helmet. Is my thinking sound?
Well yes and no.
I say that as you really can't match your physical height to a shield height as a working size ratio. You really need to sit behind and preferably ride with any given screen height to test for fit if possible.
Also other considerations come into play such as fairing height (the 09 and later fairings are fixed a bit higher than the pre-09 models), how close or far away you are to the controls via seating location etc.
Next time you ride feel for air rising from around and in front of the tank, around your legs and upper body at chest and shoulder height, jut behind the fairing and just above your head (and get your passenger to do the same) in a 180 degree arc.
If you are getting a lot of air from under the tank consider mounting a fixed air deflector beween the forks under the lower tree (if there isn't one present already).
Personal preference also plays a big role here-- some like a short screen for looks and put up with the buffeting while others take the taller route and are happy to just be able to just look over the top an inch or two (as I am).
Plenty of good reasons provided here to negate the look through the screen concept...
Also consider that if you choose incorrectly or change your mind later you can cut the screen shorter from the bottom if it's a flip, or at the top if a standard profile. I have a flip screen that I bought based on height knowing that I might have to trim from the bottom (and I did have to)-- no big deal to cut if your handy with tools-- just use another screen bottom or top as a template to mark up from.
Take your time researching, test fit yourself to other screens if possible, check where the turbulence is coming from and make your choice-- you will know if you have it right on your first ride.
One more thought-- if you like to do hard long miles turbulence and buffeting add to fatigue levels fwiw.
Old Jan 4, 2011 | 11:12 PM
  #42
WRKD4ITFLHX2008's Avatar
WRKD4ITFLHX2008
Thumbs up
Originally Posted by Old Bones
Klock Werks
second that Klock werks
Old Jan 5, 2011 | 12:18 AM
  #43
ChristoHD's Avatar
ChristoHD
Lightbulb Fused
Originally Posted by mastery
Clark's has the best custom windshields I've found. Great prices, and they will custom make it to your specs (size and tint). Great personal service, always hand sign thank yous, quick to answer questions, and are riders as well.
http://www.customflhtwindshields.net/
Originally Posted by Mike_68
LRS -
Both of these companies make GREAT shields. Clark's Custom - REALLY great people, and I like the extended width, but you will want 1"-2" higher then you think to fight some buffeting. So I have 3 shields, one short and dark tinted for tootin round town, and a large light tint for long trips.
Then I bought the LRS - that little flip they have at the top makes a world of difference for buffeting control.
So what you REALLY want is to find one that is a fusion of the Clark and LRS! IMO
Good luck on your search!
Old Jan 5, 2011 | 12:23 AM
  #44
Navy UC Rider's Avatar
Navy UC Rider
Originally Posted by 990rtracer
HD windsplitter got mine 20% off at zanotti's. Awesome!
Will that wind splitter work with the HD dash mounted GPS?
Thanks
Old Jan 5, 2011 | 12:28 AM
  #45
Navy UC Rider
I really like the LRS Ultra Flip. I bought the 8 inch originally, was slightly short, caused some buffeting. Had a buddy that it was perfect for, so we bought a 10 inch, now it is in my field of view. I guess I need a 9 inch shield.
I have a dash mounted Garmin, LRS says that if I want the X-stream, I need a 9 inch minimum. I may go for it.
Cale
Old Jan 5, 2011 | 01:02 AM
  #46
boomer's Avatar
boomer
klock werks 8.5 worth every penny. It's about 4 inches below my line of sight and don't get any buffeting yet works good in the rain.
Old Jan 5, 2011 | 12:03 PM
  #47
grandpatim's Avatar
grandpatim
I'm gonna go with the Fast Aire 8 and 9" since their cheap and figure out which size works best for me. And then buy one made of Lexan from another manufacturer.
Old Jan 5, 2011 | 12:17 PM
  #48
jjnoble's Avatar
jjnoble
+1 on the Clarks, they create a larger air pocket.
Old Jan 25, 2011 | 10:35 AM
  #49
PKDK's Avatar
PKDK
6th Gear
I use a Freedom Shield 9" light grey on my EG. Extremely easy to install and gives me the additional flip of air over the rider and passenger to significantly reduce buffeting and noise reduction. Customer service was excellent.
Old Jan 25, 2011 | 10:40 AM
  #50
SlowRain's Avatar
SlowRain
Klock Werks
+1 on this
cprhed
Mar 14, 2015 11:46 AM
RK14SGS
Touring Parts
Apr 12, 2012 02:42 PM
Skygoose
Jan 4, 2010 09:04 AM
Rodent
Oct 27, 2008 10:26 AM
2006streetglide
Apr 13, 2006 09:51 PM
