Braided lines
Old Jan 2, 2011 | 09:44 PM
bmcgc's Avatar
bmcgc
Default Braided lines
Im about to do the +2 sweeper/chrome control install and at the last minute Im thinking about upgrading to a braided clutch cable and upper brake hose.
I had intended on useing the oem brake hose and I bought the +2 clutch cable, but Ive spent so much on chrome I may as well do those items as well.
I only want to do the upper brake hose for now, I will do the others if I ever go to chrome calipers. The +2 clutch cable is all I need as well.
Anyone have p/n's and a source?
I would like to spend as little as possible to do this, xmas is still hurting the wallet.
Old Jan 2, 2011 | 09:59 PM
Texas Rapier's Avatar
Texas Rapier
I beleive you stock front brake line is a one peice unit. you can't replace the upper with out getting the complete modular assembly. Once you install the modular brake system you can change the top line at will.
Old Jan 2, 2011 | 10:12 PM
bmcgc's Avatar
bmcgc
Yep I just took a look, all pressed fittings. I guess I will just have to wait on that. Im already trying to figure out how to explain the boxes that will be showing up the next few days, I know when to stop and its time to stop.
Old Jan 2, 2011 | 10:20 PM
MSgt Rose's Avatar
MSgt Rose
Hello, my name is Rick and I am a chrome-a-holic............ Get some counseling man, you have got to stop! lol
Old Jan 2, 2011 | 10:56 PM
Texas Rapier
That the reason I have everything sent to my work. Someone always there to accept it and I don't have to explane anything!!!!
Old Jan 2, 2011 | 11:52 PM
mkguitar's Avatar
mkguitar
braided brake lines- make sure they are dot certified
braided oil/fuel lines, make sure they are resistant to petroleum products and ethanol...and not just "novelty cosmetic" lines.
I have seen the wrong lines used and expensive problems result.
mike
Old Jan 3, 2011 | 12:14 AM
captainjack's Avatar
captainjack
any one familiar with these?
http://www.magnumshielding.com/
Old Jan 3, 2011 | 06:46 AM
Texas Rapier
Magnum Is suppose to be one of the "Top Of The Line" hose companys around.
Old Jan 3, 2011 | 09:38 AM
badknees's Avatar
badknees
I'm on step 1. Admitted I was a chrome-aholic and my wife has become unmanageable.
Old Jan 3, 2011 | 10:25 AM
DuraGlide's Avatar
DuraGlide
Used their BYO brake line kits and clutch cables on last three handelbar installs I've done. Good products. Got them thru Dr V-Twin at a good price as well.
L88
May 2, 2017 09:53 AM
tmultra
Jan 2, 2017 11:36 AM
bulldog82098
Nov 20, 2016 11:39 PM
InsomniaInc
Jan 2, 2013 11:42 PM
sifularson
Sep 17, 2010 09:27 AM
