Screamin Eagle 254E Cams
I am looking for some help if you guys don't mind. I have an '06 Dyna that came with the SE Race Tuner when I purchased the bike.
I am looking for a map to get me going until I get her dynoed. If someone would be willing to point me in the right direction or even get me a map for my set up I would be willing to pay you for your time via PayPal. Anyway, this is my current setup:
3.932 Flattop pistons
254e cams
4 3/8 inch stroke wheels
50mm SE TB w/ 4.9 injectors
Big Boyz ported heads
RB Racing 2-1 exhaust
Thanks you!
-Paul
Dealer response to my inquiry on the SE254E kit:
"We are running a special right now which is $1360 for the completely upgraded cam compartment (hybrid billet plate, high flow oil pump, hydraulic tensioners, 254 cams, and all bearings and gaskets that go along with it). Doing this would also require having a full dynotune done, unfortunate part of that is that it costs $820 for the full dyno with the tuner. Tuner alone is $460 dyno labor is $315. The dyno will eliminate the popping on decel and provide hp and torque gains for mountainside pulls in the mid range rpms. We can replace cams only for around half the price of the full upgrade using the stock cam plate and oil pump, so that is an option but for overall durability and rigidity the upgrade is absolutely the way to go."
Your thoughts?....
Your thoughts?....
Your thoughts?....
I bought this bike from this dealer. I didn't know it had a stage one on it until the service manager told me after I questioned him about the type of air cleaner I had; which that question was sparked by Bitchin Baggers who put on my Bagger Brace. I asked about some pipes and he said "your gonna need a heavy breather AC" and reached behind the cover and said "oh..., looks like you already have one". He said the bike already had the stage one and to double check with the dealer to see if it had the download as well.
Well long story short, the service manager finally told me I have the stage 1 but couldn't explain what type of download. Maybe now I am being paranoid but, I feel like, what else aren't they telling me? The bike thumps/ lopes at idle, a lot more than my buddies 96ci heritage classic. How would I know if it already had some sort of cam set?
Again, it could be paranoia but when I asked them about my 1.5 front lowering kit they installed, they said it was all measured up and all was well. That same indy was like "nope, sorry, that's only an inch
Anyway, How would one know if they had stock cams or an upgraded cam set if they were not informed by the dealer, service dept or previous owner. I ask because I am interested in the advertised extra pulling power of the 254s. Don't get me wrong, the bike pulls well now but, a little more won't hurt either. Thanks all.
