clutch adjustment
Old Jan 4, 2011 | 06:29 PM
budnlucy's Avatar
budnlucy
Default clutch adjustment
Ran out of adjustment on my clutch adjuster is there any other adjustment I can do or is the cable strechted. Aredy adjusted the clutch pack.
Old Jan 4, 2011 | 06:38 PM
1931jamesw's Avatar
1931jamesw
Did you collapse the cable, then adjust at the derby, then expand the cable?
Old Jan 4, 2011 | 06:43 PM
budnlucy's Avatar
budnlucy
Yes, The handle was really loose before I adj. the clutch pack.
Old Jan 4, 2011 | 07:52 PM
budnlucy's Avatar
budnlucy
bump.
Old Jan 4, 2011 | 07:59 PM
SICKBAGGER's Avatar
SICKBAGGER
what you can do sometimes is this,
1. lossen the cable all the way
2. back off the locking nut on the adjustment screw in the primary
3. back of the adjustment screw
4. now run the adjustment screw in like normal until you feel resistance but go a little more, run it down a bit to make sure that shaft is seated well
5 back off the adjustment screw again
6 now run it in until you feel resistance
7 back it off 3/4 of a turn
8 tighten the locking nut
9 adjust cable
10 ride off
Happened to me once this worked for me.
Old Jan 4, 2011 | 08:03 PM
Papamte's Avatar
Papamte
I had that problem once. If you don't collapse the cable adjuster all the way together, you will not have enough slack after the clutch plate adjustment. Mine was hard to collapse the first time and I thought it would be enough, but you need it all the way together even if it's hard to do.
Old Jan 4, 2011 | 08:12 PM
budnlucy's Avatar
budnlucy
Thanks guys for your input. I did not have the the cable adj. fully collapsed. May be this is the problem. I will try both of your suggestions. Thanks again.
P51Driver
Jul 29, 2018 04:52 PM
rick775472
Jul 5, 2015 09:08 PM
rdondes
Oct 23, 2013 08:16 PM
Subduedracer
Jul 31, 2013 10:38 PM
Night train David
Jul 17, 2011 06:26 PM
