TBW question
Old Jan 7, 2011 | 02:45 PM
LeDouxit's Avatar
LeDouxit
Default TBW question
I have an 09 RKC I am putting apes on, pulled out the TBW harness and there is a black wire that is thicker than the rest that just dead ends about 8 in out. I am just wondering what it is for and making sure it should dead end, hope I didn't pull something off that I wasn't supposed to. All of my wires are accounted for, drew up a diagram before I pulled it off. On a side note, I am putting 18 in apes on and I am going to have enough wire with the stock harness to make it work, has anyone else had this happen. It appears to be the stock wiring, it has the green plug midway on it. Any insight would be great, thanks!
Old Jan 7, 2011 | 03:17 PM
stewy1200c's Avatar
stewy1200c
I can't answer your question, but I'm going to keep an eye on your thread cause I'm about to swap out the bars on my RK.
Old Jan 7, 2011 | 03:27 PM
slothy's Avatar
slothy
heated grips.. i cut mine short so it didn't have to be pulled thru the bars.
Old Jan 7, 2011 | 03:31 PM
08CrimsonClassic's Avatar
08CrimsonClassic
I did 16' carlini gangster apes on my 08 with TBW also and came across the same thing. Put it all back together the way it was with that wire just hanging in the bars and all worked out fine. No problems as that wire wasn't attached to anything. Don't know the reason for that wire being there either.
Old Jan 7, 2011 | 03:40 PM
LeDouxit's Avatar
LeDouxit
Awesome, thanks guys. I mapped it all out and was sure it was some sort of accessory wire but I wanted to double check. Thanks again, I will rest easier when I put it back together tonight!
dlt6855
Mar 17, 2018 03:27 PM
purpledeuce
Milwaukee Eight (M8)
Jul 10, 2017 11:15 AM
gtrplyr
Feb 16, 2016 12:22 PM
Rodney54
2014-2024 Touring Models
Sep 30, 2014 06:21 PM
waterproof
Apr 11, 2010 11:31 PM
