Header change results
Old Jan 8, 2011 | 04:41 PM
seawoo's Avatar
seawoo
Default Header change results
Has anyone changed thier header or gutted the cat on the stock header and not perform a download or add a tuner? What were the results, good and bad? I am running slip ons, everything else is stock.
Old Jan 8, 2011 | 07:33 PM
olelucky's Avatar
olelucky
i removed mine and dont have download or tuner. stock except for cvo mufflers. no problems, runs better and cooler.
Old Jan 8, 2011 | 07:53 PM
seawoo's Avatar
seawoo
Thank you for the response, I am not sure if I am going to mod the stock one or go true duels. I am currently running Super Trapp Fat Shots and it is a little quiet.
Old Jan 8, 2011 | 08:01 PM
skratch's Avatar
skratch
i gutted the cat, have a nightstick 2-1, and have not done the download or the rest of the stage 1. funny thing is, this bike will outrun my 07 that did have the stage 1, with pciii, and get better mileage while doing it.
Old Jan 8, 2011 | 08:12 PM
seawoo's Avatar
seawoo
I like the sound of that...
Old Jan 8, 2011 | 10:39 PM
Valkyrie's Avatar
Valkyrie
I just removed the two-into-one system off my 08 Ultra. Purchased true duals for such a great deal I couldn't not buy them. Not really crazy about the way it runs (killed the low end grunt) but it sounds sweet. The 2-into-1 system started looking ratty. And I take very good care of my bike. The chrome was peeling off the end piece and I had some minor scratches where I got boot goo on them. Mfg said no replacement shields were available. Hoping the true duals last a bit longer than the two into 1
Old Jan 9, 2011 | 12:10 AM
TCMAN's Avatar
TCMAN
Yes I gutted my cat and can say bike runs great and sounds nice; completely stock otherwise, 2011 Limited btw.
Old Jan 9, 2011 | 12:57 AM
CT-Bagger's Avatar
CT-Bagger
If you have a cat. you will never pull it off.
It will run too lean.
PCV is the way to go
Old Jan 9, 2011 | 01:19 AM
skratch's Avatar
skratch
i disagree. if you just lose the cat and add a slip on muffler without adding a free flow ac, it'll be fine. it'll still run epa lean, but not overly lean.
Old Jan 9, 2011 | 02:03 AM
RockerBob's Avatar
RockerBob
I rode my 2010 Limited with a Fullsac (cat-less) header two or three times before I flashed the ECM (using TTS Mastertune, with a dyno-tuned map that I got from Fullsac).
The bike definitely ran better than stock with the new header and without tune, and I wouldn't say I noticed anything "wrong" with it (at least compared to before the header). But doing the tune made a noticeable difference in my case (more power, much better low-end grunt, and crisper throttle response).
Harley Limited
Aug 3, 2015 03:00 PM
sifularson
2014-2024 Touring Models
34
Apr 16, 2015 11:24 PM
CGP93
Dec 12, 2012 09:38 PM
Black Sunshine
Sep 12, 2012 09:22 PM
punkmxcn
Feb 4, 2012 01:02 PM
