Muffler removal help please
Old Jan 13, 2011 | 09:30 PM
albngore's Avatar
albngore
Default Muffler removal help please
2006 Ultra
In the Fix My Hog video it says to remove the heat shields first, then remove the mufflers. After looking at my cycle it seems to me that I can remove the Torca clamps, or at least loosen them sufficiently to wiggle the muffler off WITHOUT removing the heat shields. Am I missing something here?
I have the V&H Ovals although I doubt this makes any difference. I am doing this to remove my rear tire and since I do not have the HD 90-degree wrench, the muffler removal is necessary.
Any advice on just loosening the Torca clamps?
Thank you.
Old Jan 13, 2011 | 09:39 PM
imskier2's Avatar
imskier2
No need to remove the heat shields, just the clamps and the 2 bolts under the saddlebags.
Old Jan 13, 2011 | 09:46 PM
albngore's Avatar
albngore
Thanks. I did find a few other posts saying the same thing. I'll use some penetrating oil first.
Old Jan 13, 2011 | 10:33 PM
user 8373900's Avatar
user 8373900
If you take the rear hanger loose you might get the muffler to drop far enough to get the nut off and pull the axle, I did.
Mark
Old Jan 13, 2011 | 11:52 PM
bagman1's Avatar
bagman1
Use neverseeze on the joint when you put it back together, for the next time it will come off with ease.
Jarno90
Mar 12, 2015 02:11 AM
jcanrun
May 12, 2010 03:52 PM
Kumite
Oct 22, 2009 07:47 AM
ozzrahog
May 10, 2008 10:15 AM
heavy hauler
Apr 10, 2006 03:22 AM
