hardwire garmin plug to cig lighter?
Old Jan 14, 2011 | 08:58 AM
alkrisma's Avatar
alkrisma
Default hardwire garmin plug to cig lighter?
is it possible to hardwire my garmin power plug to the rear of the cig lighter (inside fairing)? I saw j&m has something the plugs into rear of lighter plug as well. was thinking I could strip the ends of the garmin wire. anyone?
Old Jan 14, 2011 | 09:07 AM
sgdiesel's Avatar
sgdiesel
The main thing to appreciate is that, generally, all these types of devices are powered off 5V, so to achieve this the cigarette lighter plug on the charger has some electronics inside that are crucial for charging. Providing you keep these electronics or source a product that performs this same function then you can wire straight on. I believe there are a number of companies that sell these, just google it.
Bottom line, you can't just cut the plug off and join the wires
Old Jan 14, 2011 | 09:16 AM
dougk33's Avatar
dougk33
Here is what I have and use for my bike and car. http://cgi.ebay.com/Garmin-Direct-Wi...item27b561bc84
I have wired it into a quick connect to the charge port for the battery that way can take on and off but could easily be run under tank and seat for perminent connection. Hope this helps
Old Jan 14, 2011 | 09:20 AM
Rustell's Avatar
Rustell
SGdiesel is right ..don't just cut the plug off your cig/lighter.
I got something like this... http://www.amazon.com/Arkon-GPS-NHWC.../dp/B002GU60CE
Hard-wired it to the back of the cig/lighter.... works great.Powers off when you turn off your bike.
alkrisma's Avatar
alkrisma
can I route the wire under the tank with removing it? (bike in dealer storage so I can't go look at it)
Old Jan 14, 2011 | 09:24 AM
alkrisma's Avatar
alkrisma
did you solder it to the lighter spades inside fairing then zip tie everythig?
Old Jan 14, 2011 | 09:37 AM
Rustell's Avatar
Rustell
Exactually what I did.
Old Jan 14, 2011 | 09:40 AM
sgdiesel's Avatar
sgdiesel
Or you can get "piggyback" spade connectors, that is what i have used in the past
Old Jan 14, 2011 | 10:11 AM
albngore's Avatar
albngore
There are two unused OEM wires zip tied to the headlight wiring. Why not use those as long as you will be inside the fairing?
Old Jan 14, 2011 | 11:23 AM
FLUltrarider's Avatar
FLUltrarider
Garmin makes a bare lead power cable for it with the in-line fuse and a converter that I used to wire mine to the cig lighter. I just used to snap close wire splices and taped the bare end with electricqal tape so it wouldn't touch anything in the fairing and possibly short. Zip tied everything up neat and trim and viola, works like a champ. When the bike's turned on the GPS comes on, when you shut down the power it goes to battery if you're just temporarily stopped for lunch or a gas break, or you can shut-it down too. Works great. Check Garmin.com and find the one for your model.
