Fuel Stabilizer
Old Jan 15, 2011 | 10:54 AM
HOGNOT's Avatar
HOGNOT
Default Fuel Stabilizer
Business travel will require leaving my bike sitting in the garage for up to a couple months at a time this year. I've used fuel stabilizer products in lawn mowers and such to prevent carbs from getting gummed up. Can I use the same type of stuff in my Ultra's gas tank? Any specific brand recommended?
Thanks,
VR
Old Jan 15, 2011 | 11:01 AM
Dionicio's Avatar
Dionicio
Yep, You can use it with no problems. I use Sta-Bil.
Old Jan 15, 2011 | 11:05 AM
bill1nat's Avatar
bill1nat
I use the same thing on my 08 ultra
Old Jan 15, 2011 | 11:08 AM
tazmnaz's Avatar
tazmnaz
Sta-Bil is the most popular brand that I have used.
Old Jan 15, 2011 | 11:22 AM
vtwinbob's Avatar
vtwinbob
i tried the new sta-bil this year, for ethanol gas--
Marine Formula STA-BIL
Old Jan 15, 2011 | 11:46 AM
RK Ivan's Avatar
RK Ivan
Sta-bil or Sea Foam I don't have experience with any others. I use Sta-bil with the ethanol gas nowadays...
Old Jan 15, 2011 | 11:59 AM
ZZZCICI's Avatar
ZZZCICI
I have used both products, sta-bil and sea foam. I have seafoam this year. It is a good idea to add one of the additives to the gas tank. A full tank of gas is best if the bike is going to be stored for a few months, add product as directions indicate. Run or ride the bike so the product is throughout the fuel system, then you are good to go.
I like to add sea foam to the gas tank during a fill up at least once every few thousand miles, or if I get gasoline that may be suspect or a lower grade than I like.
Old Jan 15, 2011 | 12:11 PM
ucommbxny's Avatar
ucommbxny
use stabile added to tank as per instructions before i filled up and took the long way home to get it through the entire fuel system
Old Jan 15, 2011 | 12:34 PM
ddm502001's Avatar
ddm502001
A newer product to come out in good standing with my indy is Star Tron, it is a enzyme fuel stabilizer and prevents(by evidence)the separation of ethanol from gas as it absorbs moisture. I started using it as a stabilizer/octane support and I am very happy with the results.
Old Jan 15, 2011 | 12:42 PM
HOGNOT's Avatar
HOGNOT
Okay, thanks to all for the replies.
VR
STA-BILŽ
Dec 12, 2014 09:42 PM
William C
Oct 17, 2014 03:42 PM
DavidStiebel
Jan 4, 2013 03:11 PM
sportster2009
Nov 9, 2009 04:09 AM
girlslikechef
Oct 25, 2008 09:05 AM
