My dieing is back...
Old Oct 2, 2006 | 07:10 PM
bucs012's Avatar
bucs012
Default My dieing is back...
07 RoadGlide now with 1600 miles on it. As some of you know I had a problem that started at about 800 miles. Bike just died while at hiway speeds. Dead. Happened 3 times within 200 miles. Took it in and has HD go thru everything. Said they could find nothing. Funny thing is is that it STOPPED right after I took it in the shop......until today! 600 miles later and it's BACK.....90 miles into my ride today and it did it twice within 15 miles apart at hiway speeds. [:@] Then was fine the other 100 miles I rode......... Ahhhhhhhh!
Old Oct 2, 2006 | 07:21 PM
gunrunner's Avatar
gunrunner
Default RE: My dieing is back...
What fuel mangement are you running? PCIII ? cause it sounds like it could be a ecm problem
Old Oct 2, 2006 | 07:24 PM
bucs012's Avatar
bucs012
Just running the Harley system. They even remapped it. What are your thoughts?
Old Oct 2, 2006 | 07:33 PM
bountyhunter's Avatar
bountyhunter
Does it start right back up after it DIES? Does it happen at cruising speeds, when you are slowing down to stop, or accelerating from a stop? Could be a tuning issue....a PCIII would solve that!
Old Oct 2, 2006 | 07:34 PM
Mr Wonderful's Avatar
Mr Wonderful
I have a friend that had an Ultra with Stage 1 download. His bike kept dying and the service department went nuts trying to figure it out. Even HD was struggling with it until someone discovered they had downloaded the incorrect program into the ECU. This might be the cause of your woes.
Old Oct 2, 2006 | 07:46 PM
gunrunner's Avatar
gunrunner
Id say thats your problem, just a FYI all harleys downloads for the 07 are regulated and EPA compliant, even if they did the correct download it still is not running its best. I have the vance and hines fuel pack for mine it was setup by them for the 07 or the PCIII from fuel moto might be a option, they are the only ones offerering 07 maps so far but I think you have to remove the 02 sensors, they stay in place with the fuel pack. but bet that will cure your problem and make it run much better. IMO
ORIGINAL: bucs012
Old Oct 2, 2006 | 08:20 PM
Chiledog's Avatar
Chiledog
What of fuel petcock do you have? Several years back I had a suzuki that had a vacuum control fuel petcock - no manual lever - it opened based on suction from the engine.
Took a while to trace the problem to it- turned out it was defective and would just shut closed while riding
Old Oct 2, 2006 | 08:24 PM
vulhalla's Avatar
vulhalla
I had a 87 Low rider and it kept doing that, well come to find out the gas cap vents were clogged so it caused a vacume, weirdest thing. After replaceing that, it was fine.
Old Oct 2, 2006 | 08:33 PM
pittguy's Avatar
pittguy
Bucs02 mine did the same exact thing but only once,had dealer write it up along w/engine noise issue.
Old Oct 2, 2006 | 08:37 PM
hoosierrkc's Avatar
hoosierrkc
5th Gear
Sounds like a crank sensor issue. The 07 's are having problems with them.
