Draggin Bagger pis
Old Oct 3, 2006 | 03:19 PM
rpt63's Avatar
rpt63
Default Draggin Bagger pis
Ok I am still learning how to post pics, here are some installation pics and some pics of the bike raised and slammed. I did remove the battery box so I could mount the comp,(I liked the way Roady did the valve on his bike).I mounted the switch on the right side of the bike ,the hole did not need enlarged and I won't be doing much adj on the fly so it was not a issue with me. It did take me a lot longer taking the battery box out but a very clean install,hope this helps some one. I do enjoy this system. Safe riding.
Size:  134.0 KBName:  DragBaginst010.jpg
\ket.com/albums/l320/rpt63/DragBaginst012.jpg[/IMG]
Old Oct 3, 2006 | 03:35 PM
jmorton10's Avatar
jmorton10
Default RE: Draggin Bagger pis
Nice, I have that setup on order for my 04 RK Custom MY BIKE
I have been running Progressive 440 shocks for a couple years & the ride is super. It will be interesting to compare the ride of the two setups.
~John
Old Oct 3, 2006 | 03:48 PM
RonH's Avatar
RonH
Looks great! nice clean install too - Congratulations!
Old Oct 3, 2006 | 04:11 PM
roady's Avatar
roady
Nice job!!! I wanted to use the hole on the right for the swith but my switch would not fit. The hole was the right size but there was some metal behind the hole and the back of switch would not clear. Did you have fun removing the battery tray as well ? Once I got that part figured out the rest was a breeze. Enjoy!!!
Old Oct 3, 2006 | 04:32 PM
bountyhunter's Avatar
bountyhunter
Nice job, cool to see the different layouts possible on the install. I prefer the comp under the left side cover, switch on the left, cause it's just real easy to get at & operate. How's the RIDE?
Old Oct 3, 2006 | 05:36 PM
Rocket Jockey's Avatar
Rocket Jockey
Default Battery Tray....*&#(&^%#$!!!!!
OK, I started my install last night. I have an 04 RG with cruise so I had to mount under the battery tray. I like to think of myself as fairly mechanical but that battery tray just about did me in. I got it out but I am pretty sure I didn't do it right....trust me, I didn't do it right. So, what is the trick?? Please describe the removal.
I am hoping to finish tonight.....
RJ
Old Oct 3, 2006 | 06:09 PM
kdietz's Avatar
kdietz
Default RE: Battery Tray....*&#(&^%#$!!!!!
ORIGINAL: Rocket Jockey
RJ
Slides out on the right side....remove all the electronics on that side....hold your tongue just right and pull
Old Oct 3, 2006 | 10:08 PM
FirstHarley's Avatar
FirstHarley
I did mine a bit different.I put the compressor in the r/h saddle bag mounted on the side at the angle of the bag with the nose down against the bottom on a soft pad on the inside wall Used a 2-prong plug on the power and a quick disconnect on the air line to make it simple to remove the saddle bag.Bolted the dump valve to the backrest mount.Compressor doesn't take up that much room.Made a bracket for the switch and pointed it out and up about 45 degrees.Will post pic's later........... JerryB
Old Oct 3, 2006 | 11:53 PM
Richking's Avatar
Richking
Nice Clean install, I'm Waiting on the same for My 04 RK Custom.
Will have to go under the battery box as I've put cruise in the left side cover.
Looks great.
clap
Mar 5, 2014 05:41 PM
NightTrain4Al
May 4, 2012 04:03 PM
MZBuckeye
Feb 23, 2009 05:33 PM
Drifting Texas
Feb 16, 2008 10:19 PM
roady
Oct 26, 2006 03:17 PM
