Tour pack question for 2011 streetglide
Old Dec 21, 2011 | 03:21 PM
Mntsnow's Avatar
Mntsnow
This is basically what needs to be done.
My metal baseplate inside my pre-08 chopped tp actually had all the needed holes but the actual abs of the tp needed to be drilled. I show were the holes basically end up being. You can use part #11875 (spacer) or as I did and just used a couple of pieces of flat stock I had laying around in the garage to make up for the height of the rib that the rear mounting hole use to keep the TP level on the mount. I used the solo mount for my chopped and put my King TP on a 2up mount.
Attached Thumbnails Tour pack question for 2011 streetglide-chopped-pak-drill.jpg
Old Aug 6, 2013 | 09:19 AM
Nefariousone's Avatar
Nefariousone
Stage III
Hey TFB, I know this thread is a couple years old but hoping you can help me with the part number the spacer bar (about 6" long and 1/4" thick) for mounting an older chopped tour pak to a newer Street Glide. My local dealership says they don't know the part I'm talking about. Thanks.
Pete
Old Mar 25, 2019 | 09:29 AM
usera1365's Avatar
usera1365
Hi
Any chance you still have the pictures of the spacers used to mount the tour pak in the Front?
I have a 2013 RG tryna mount a AdvanBlack Pak and the pak is not sitting flat on my mount. Looking
for some advice.
Thanks
AdrianT
Apr 24, 2018 04:18 PM
2WheelThrill
Apr 8, 2011 11:58 AM
casique
Dec 4, 2010 09:02 PM
dawg
Aug 29, 2010 09:16 PM
user 8373900
Aug 27, 2010 12:02 PM
