as long as all you're putting on is a standard auto/bike type horn, you're good. if you put on a air horn with a compressor, you need a relay cause the compressor draws more power. I put on two fiams, a high and a low, with no relay, with no problems.
Like ruin66 said, air compressor horns can quickly run out of air when not using a relay, but you don't always need one. What does the manufacturer say? If it needs one they should tell you.
