Dyno tune or auto tune?
I'm trying to decide what tuner to get when I get new a/c, pipes, etc. My dealer uses TTS Mastertune and have 2 friends that have had them tune their bikes and they are really happy with the results. I only plan to Stage I but realize that could change down the road. I'm pretty sure I don't want another add-on (had PC3 on last bike) but rather an ECU flash like Mastertune, HD SERT (whatever the hell they call it now), or the Dynojet Vision.
Has anyone that has one of these (or other ones) with the auto tune ability ever had the bike dyno'd to see how good the auto tune works? I'm not sure if my dealer is this way but I've read about dealers just loading the closest map and dyno for show and call it done. I don't want to spend a fortune but want a well tuned bike when it is done.
I know there are plenty of folks who dyno after every change, but I think it's a waste to chase 2-3 HP with $300-500 for a dyno if the bike is running well with a proven map. On a stage 1 anyway.
TTS is a gold standard for fuel mgmt, and even better if that's what your shop specializes in.
I absolutely KNOW that you are correct about some dealers using a dyno just to confirm a dload and charge big $$. My closest dealer guy recommended a dyno tune with an SE a/c on my wife's bike. I tested his honesty by asking how long he thought it would take. He said "about an hour." Ripoff time.
Just bought a new bike myself, I'm going TTS again. Good luck!
I’ve done one bike with the Master Tuner and dyno. It turned out real well also. The Master Tuner gives the tuner a little more access to the computer like exponential control on the fly by wire throttles and other parameters not in the Super Tuner. Again it depends on the tuner how well it turns out.
I installed the Thunder Max with auto tune on one bike and still had to have timing adjusted. I had a problem with the fuel pump initiation circuit in the first year. I called a dealer about helping me fix it and he pretty much told me to go to someone else. He also told me warranty was void. I’ve heard all the stories about they have to prove that the tuner was the cause and all that stuff however when it gets down to it who’s going to tell the dealer that and make him work on my bike. Anyway I removed it and threw it in the trash. I reinstalled the stock computer and had it set up on the dyno with the Super Tuner. I’ve been very pleased with the performance.
Thanks for the help!
I don't have any comparison to a dyno but they claim this unit will be within a pony or two of a dyno.
the other thing I like is that this unit keeps all of the factory safeguards. Not all units do this, especialy add on units. Also keeps all factory trouble codes as the "tuner" uses the factory ECM. My understanding of the unit is that it allows the HD ECU to read and write to the AFR and VE tables using wide ban O2 sensors.
Just another option in the vast world of tuners. But if you are not planing anything crazy but want to have the ability to change at a later time with maps and dynos this might work very well for you. They run about $640 if you look around. They are new as of November but I believe they just came out in Drag catalog. Also, Drago's bike works a sponser on this site is selling them for a very good price.
Of course if you are looking for crazy, I did talk to one guy who was working with Rev Perf to come up with a EMS tuner that will work for supercharged bikes!!
Before the TTS I tried the Power Commander V. A lot of people have very good results with it and are very happy, but I was not one of them. I tried custom maps from Fuel Moto, there is no lack of support from those guys, but I just could not get one that was right, I tried the auto tune, that did not work either, I even had the bike dynoed, that should have worked but it is very hard to find a good dyno tech, a lot of people do it, but not many know how to do it. I was tired of wasting time and money, so I gave up on it and went to Docs and got the TTS.
Very easy to spend a lot of money. I think it is better to go with the TTS Mastertune, try the Vtune if you like, if you end up needing a dyno, don't waste any money on people who say they can but know nothing, just go straight to Doc, make a trip out of it, have some fun. If Doc is to far away, call him and get a reference, he trains TTS tuners for the Mastertune company, if there is a good one in your area, Doc will point you to him. At least call him and talk about what you should do.
Hope that helps
Here is the link to Docs web site: http://www.docsperformancetuning.com/
Doc's Performance Tuning
352-404-6999
317 E Washington St. unit AMinneola, Florida 34715
