New tail light help
Old Feb 9, 2011 | 08:48 AM
MILLER41143's Avatar
MILLER41143
Default New tail light help
I just put the bag extensions on my 10 sg and since i have the 2 into 1 exhaust it looks dumb with the left side blank. so i found on ebay a tail light from a 32 ford (reproduction tail light that is chrome and says stop)
Im wondering how to make this a run/brake light?
Old Feb 9, 2011 | 09:11 AM
KCFLHRC's Avatar
KCFLHRC
If it's a dual element socket it will accept a 1157 type bulb and it will work as a tail light and brake light.
Old Feb 9, 2011 | 09:18 AM
MILLER41143
so where should i tap into the wiring at? i am guessing one wire would wun to the run-wire & one to the brake- wire?
Old Feb 9, 2011 | 09:21 AM
KCFLHRC's Avatar
KCFLHRC
I think I would try and tap into the wire under the seat somewhere.
Old Feb 9, 2011 | 10:49 AM
KING'S RIDE's Avatar
KING'S RIDE
i tapped mine in at the brake light housing with the brake and running lights. then ran the wires down along the inside of the fender. not the same install, but the concept is the same.
Old Feb 9, 2011 | 10:52 AM
MILLER41143
alright thnx man i think im gonna try the same but run the wires down the inside of the saddlebags
Old Feb 10, 2011 | 04:59 PM
MILLER41143
Default help
just wanted to ask again
can i tap into the rear ascia light?
and i so does anyone know what wire is a run wire and wich is a brake?
Old Feb 10, 2011 | 06:27 PM
KING'S RIDE
not sure it is the same on yours but on mine there was a four prong plug in the tail light. in the first slot was a blue wire=running light. 2nd=empty. 3rd=red wire brake light. 4th=black wire ground. if the light you bought has 3 wires connect them accordingly. if only 2, i think only the red and black.
you can always splice the wires, and try them on different connections. if everything goes dead then you blew a fuse. its a 15 under your left side cover.
I am not an electrician, so this is the best i could do to describe how i did mine. hope it works out for ya.
Old Feb 13, 2011 | 08:35 PM
MILLER41143
Default Finished!
thanks for all the help im very pleased with how it turned out
http://www.youtube.com/watch?v=lr-phatZr4o
hhkiwi
Apr 15, 2015 03:41 PM
Yuckieboy
Nov 21, 2012 09:28 AM
RatBob13
Electrical/Lighting/Alarm
Nov 10, 2012 10:37 AM
lou1
Oct 18, 2010 09:50 AM
mikey0086
Nov 25, 2007 05:28 AM
