Washing a Bagger
Old Feb 12, 2011 | 01:01 AM
asandler's Avatar
asandler
Default Washing a Bagger
After 8 Harleys, I have now bought a 2011 Street Glide 103ci. Not having owned one with a sound system on board - I was wondering how careful one has to be when washing the bike, particularly the inside of the Batwing fairing. Surely getting water into the speakers is going to be detrimental. Thoughts and advice, please.
Old Feb 12, 2011 | 01:29 AM
JohnScrip's Avatar
JohnScrip
You don't want to hit them with a hard stream, but a little water isn't going to hurt them.
Old Feb 12, 2011 | 01:34 AM
ThaGlyde's Avatar
ThaGlyde
Amen, some water will hold. A flood will not.
Old Feb 12, 2011 | 04:00 AM
asandler's Avatar
asandler
Thanks, guys, I'll keep the Karcher pressure cleaner well away from the dash!
Old Feb 12, 2011 | 05:53 AM
Johan96's Avatar
Johan96
Do not use the Karcher, use a normal hose
Old Feb 12, 2011 | 06:01 AM
hawwk's Avatar
hawwk
I never use a pressure washer on any bike. They have to much force and force water in places it should not be. I just use a normal hose and spray lightly on the dash areas. That way it is no different than being in the rain
Old Feb 12, 2011 | 06:09 AM
Iceman24's Avatar
Iceman24
Even though you can, I never directly spray water over back side of fairing (dash, radio, speakers, gauges, etc.). Just wipe with damp cloth & dry w/soft towel...works for me & I still haven't had any moisture appear in gauges (like ID'd on other posts).
Old Feb 12, 2011 | 06:46 AM
lionsm13's Avatar
lionsm13
For cleaning, I mostly just use moist cloths and put them on the bike let them soften up up the crap and then wipe it off, and rinse with a cleaner moist cloth, followed by Thunderbolt polish. Same as you'd do for bugs too to soften them up, maybe a degreaser and a light spray for underneath if needed to get the road grime off but that'd be about it. No direct spray for me, don't see the point.
Power washers put water where it shouldn't go..
Old Feb 12, 2011 | 06:49 AM
geargrinder's Avatar
geargrinder
There are times, such as a lot of road spray, when I use a high pressure car wash. However, when spraying the back of the fairing or around the side covers, I keep the spray nozzle way back to reduce pressure.
Never, never set your hard bags on the floor and hit them with water pressure without holding them down or they will tip and go skidding across the concrete scratching their paint as they bobble around. I knew that but it happened to me anyway last night.
Old Feb 12, 2011 | 06:58 AM
djaudette's Avatar
djaudette
Sweet looking sled ThaGlyde
