2007 FLHTCU and Fuelmoto Vision
Old Feb 14, 2011 | 08:12 PM
Brad Grey's Avatar
Brad Grey
4th Gear
Default 2007 FLHTCU and Fuelmoto Vision
I have a 2007 FLHTCU that has no modifications and runs very hot. Iv'e been told the HD has a ECM download that would richen the fuel mixture a causing the system to run smoother and cooler.
Recomendations have been:
1. spend the $200.00 on a stage 1 download then $180.00 for stage 1 intake.
2. spend the money on $460.00 and 2 hrs install and dyno and $180.00 for stage1 intake
or
3. Purchase the Fuelmoto Vision and air intake upgrade that would cost about $320.00
Any thoughts on this?
Thanks in advance
Old Feb 14, 2011 | 08:39 PM
Avalanche_Mutt's Avatar
Avalanche_Mutt
option 3 Fuelmoto all the way!!
Old Feb 14, 2011 | 09:20 PM
stro1965's Avatar
stro1965
You can buy an intake AND the Vision for $320?
Old Feb 14, 2011 | 09:49 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Might be simpler just to sell the '07.
Old Feb 15, 2011 | 09:39 AM
kjelders's Avatar
kjelders
I talk to Jamie at Fuel Moto yesterday and ordered this
Should be here by Friday
Old Feb 15, 2011 | 01:02 PM
Gigg's Avatar
Gigg
I have a 2007 FLHTC that also ran very hot. I bought a stage 1 from Fuel Moto at the beginning of last season. Jamie helped me alot. You will be very pleased at the better response very little pinging and the much cooler running of your bike.
Gigg
Old Feb 15, 2011 | 02:13 PM
iclick's Avatar
iclick
The HD download makes no significant changes and mostly just alters some ignition-advance settings. Also, the AC shouldn't cost $180.
I assume this option is SEST with two hours on the dyno, but that is not enough time for a thorough tune.
Now you're on the right track. I assume you mean the FM tuner and AC, as the PowerVision is around $500 without the AC. This is the best way to go from among those you've listed, and IMO the best bang-for-the-buck option available. OTOH I would consider spending a few more $$ and buy the PCV, however, as it is a more current design than the PCIII-based FM tuner, has more features, and you can add Auto-Tune later if you want. The Fuel Moto choice is excellent because you can buy a tuner with a good map installed for much less than other tuners that will require a dyno-tune to be set-up optimally.
Old Feb 15, 2011 | 02:15 PM
iclick's Avatar
iclick
Why? If he sells the '07 and buys a newer bike he still needs a tuner and AC.
Old Feb 15, 2011 | 05:46 PM
paguy's Avatar
paguy
07 RKC. Got tired of it riding hot. Got the fuelmoto AC, Jackpots, and Fuelmoto PC, preset. Got the O2 sensors out with the FM jumpers.
Midddle of last summer got stuck in an hour of stop and go through a small town. Reached down to feel my motor. Didn't feel as good as a cold beer, but it wasn't HOT.
Old Feb 15, 2011 | 06:15 PM
SICKBAGGER's Avatar
SICKBAGGER
Talk with Jamie at Fuel Moto there are many options for you to spend all the money up front or progressively buy the key parts. I am so satisfied with my PCV and Auto Tune words cannot describe. They are always there for you to support you and get you running right with in you budget bracket. Can go wrong you will be satisfied and if you have a problem it will be resolved in no time.
