.....I had my last dyno tune at battlefield HD and it worked ok but was done in under a hour, thats pretty fast to tune don't ya think....
All the dyno folks I've talked to say ~5-6 hrs average to get a really good tune. If Battlefield only took an hour I'd question if they even rolled in on a dyno...
Originally Posted by bagger76 I have been to Zepka's it's a nice shop maybe i will call Brian and talk to him.Anyone else have a tuner around PA or Maryland.I had my last dyno tune at battlefield HD and it worked ok but was done in under a hour, thats pretty fast to tune don't ya think.And what about the break in time.
Originally Posted by Lonewolf176
Brian like Dave at JD's has been trained by Doc. Break it in on the dyno.
Right here would be a good starting point. Doc would be the best trainer, but not everyone has the ability to learn, these guys probably learned just fine, I'm not saying they didn't. Give Doc a call and ask him, he's a nice guy and won't bite your head off. If you get a bad tune it will end up costing a lot of money and aggravation, make sure it is done right the first time. Call Doc, if there is a good tuner in your area he will tell you.
Doc's Performance Tuning 352-404-6999 317 E Washington St. unit A
Minneola, Florida 34715
You can do a V-Tune in your garage, with bike idleing with slight throttle increases.
It will give you a reading that you can blend with the map you have selected that will get you a better tune.
It may help to give Steve a call at TTS, he can walk you throught this.
310-669-08101
-Dusty
Agreed. They probably already had a map on file for that set-up. Beats the hell out of paying for hrs. on the dyno. Better yet is doing the tune yourself as instructed with the TTS kit.
