From: 12 year, Colombia, 4 years Mexico, currently In Kuwait, but Boston is HOME!!
I did not know they made them, if I did I would have put them in. I got the three way for the freeway with a hog pod with the amp and it is loud but does get distorted a 3/4 volume. Maybe with the 7" woofers I would have more bass and less distortion.
I have the Big Ultra Kit installed (NCA40.4 AMP) as the FL-7W (7 inch woofer) has to have to power up. I did the Big Ultra Kit and the FL-7W kit at the same time. This sound system is a beast over stock. I had no in between system (Stock to Big utlra with FL-7W)
Love it so far, only complaint that I have is that the Rear pod speakers are now plugged in to the Speaker Pass threw (Blue Plug) this plug is actually Front out for radio power. Fader works as a Balance for Lower Woofer and Front Fairing speakers. Rear pod speakers are hooked to the same Side of the Balance as the Front Fairing speakers and are Being powered by the Radio. What this means is the Rear Pod speakers that are already Weaker are turned down even further when you Pump up your Lower Fairing Speakers.
Can I still hear the Rear pods Yes just not as loud as I Wish they where. Is this System better than Stock yes. So Far I love it. I have noticed a High pitched Wine sound even with the Bike not running. But This is a Fresh install and I have learned not to panic that some times these things need a Little Break in time to Clear up.
Hope this helps any one interested in these systems.
