Lock tight
Old Feb 21, 2011 | 10:18 PM
05ROADGLIDE's Avatar
05ROADGLIDE
Default Lock tight
Doing cam swap on my 05 roadglide. Read up on it on here and saw alot about blue locktight on cam plate and oil pump bolts can't seem to find that in my manual. Is it recommended to use locktight
Old Feb 21, 2011 | 11:10 PM
dawg's Avatar
dawg
Some use it, some don't. Manual states only to torque to spec, 90-120 inch pounds. The bolts in the camplate positions #1 and #2 in the torque sequence, do those at the bottom of the scale (90 inch pounds) so you don't strip them as there is not much for threads on those two because of the dowels.
Old Feb 21, 2011 | 11:16 PM
05ROADGLIDE
Ok cause when I took them out was not any old lock tight on threads was just curious thanks dawg
Old Feb 21, 2011 | 11:23 PM
Tek74's Avatar
Tek74
If you decide to use blue loctite, its loctite 242. I use this stuff all the time for stuff.
Old Feb 22, 2011 | 03:11 AM
emwolb's Avatar
emwolb
i just wish the loctite people would put red loctite in a red squeeze tube, and blue loctite in a blue tube. i guess that would make too much sense. while they're at it, they could do the same with purple and green loctite. it's a conspiracy i tell ya.
Old Feb 22, 2011 | 04:25 AM
shortride's Avatar
shortride
Some times when you torque bolts to factory spec's, thread can get distorted. In some cases it is recommended that you replace bolts verses Loctite. If I were going to use original bolts, I would use Loctite.
oldtoad
General Topics/Tech Tips
Apr 4, 2019 06:21 PM
sanman4ever
Jun 10, 2014 08:48 PM
skully1200
Jan 28, 2012 06:06 AM
lt1tyrell
Exhaust System Topics
Sep 18, 2011 11:00 PM
cpotts454
Jun 15, 2010 09:38 PM
