Wobble in Front End upon Deceleration
- bike on lift with rear wheel touching the ground, front fork/wheel relaxed
- one person stays on the bike and presses the brake to block the rear wheel
- the other person grabs the front fork near the axle of the wheel for longest leverage (the front wheel doesn't need to be removed)
The evaluation of the play is done by pulling and pushing the fork in line with the frame: there should be very little or no play on the radial load bearing.
In case of loose neck bearings (my case) we need to tighten the fork bearings several times to make sure the bearing races are well seated. Once blocked these bearings need to be released by a 1/4 turn and not more. The neck bearings are not submitted to rotation and cannot deform by overheating. There is very little risk of race damage (marks) when overtightened, but damage may occur when there is slack in the assembly and opposed bearings can vibrate during contact. If stiffer angular positions are found, the fork needs be dismounted and inspected by a technician; there could simply be dirt on the races or damage due to poor contact.
My dealer did at 5,500 miles and found the Tire run out was over 30 oz., I got a new tire - problem solved
Items to check:
1.) Front 32 psi / Rear 42psi - Tire pressure - +/- 2 psi Cold
I check mine prior to every ride
2.) Rear Axle - make sure it is in aliment - the brake side will some times
move away from the swing arm jam weld and you will have a gap.
3.) Presure in Air Shocks - play with this - if running on low side - pump it
up - 5 psi at a time. I found at my weight if I run at 15 psi or lower the
front end does get "light"....
4.) Belt - make sure the belt is at required spec.
5.) I run a Red Line CV-2 Grease in all my bearing area's - Head Bearing
