Problem installing Biktronics BT 1005 module...no 12VDC unswitched out from module
Old Feb 27, 2011 | 03:22 PM
DrPlastic's Avatar
DrPlastic
Default Problem installing Biktronics BT 1005 module...no 12VDC unswitched out from module
I know...I know I will call them in the morning but I just wanted to know if anyone has had the same issue. Has anyone had warranty problems with Biketronics with this type of issue?
I am installing this in my '08 Electraglide standard with an Alpine CDA-9855 head unit. I disconnected everything as directed in the instructions and soldered all wires. I installed the two 15A fuses in my fuse box for the radio. Power is coming from the fuses. I set the module to "3" as directed on the website. I have no 12V DC out from the module to the radio. I have 12VDC switched (red) but no hot 12VDC at the yellow wire into the head unit. The same is getting to the module on the orange/blue wire at the plug.
Thanks for any help you all can provide!
Old Feb 28, 2011 | 01:12 AM
ThaGlyde's Avatar
ThaGlyde
Dr. I know this sounds like a crazy question but did you throw a meter on the wires to measure voltage before you wrapped it up? I installed that same alpine unit on my bike.
Old Feb 28, 2011 | 04:44 AM
DrPlastic's Avatar
DrPlastic
ThaGlyde
Yes. When I first installed the system all the fuses were out. after putting it all together I installed the two fuses and 12VDC switched and unswitched is getting to the module. The radio does work as I jumpered the switched voltage coming out of the module to the unswitched and system powered up. Plus the handlebar switches do not work either.
One question concerning the Alpine CDA-9855....how do you adjust the EQ curves. I get into the EQ section but the book says to press the "band" button to select each frequency, mine does not do anything. Any idea? PM if you can provide any insight!
Thanks!
Old Feb 28, 2011 | 03:29 PM
DrPlastic's Avatar
DrPlastic
Well that was painless.....Called Biketronics and they are sending me another unit. I should have it by the end of the week!
Old Feb 28, 2011 | 05:53 PM
ThaGlyde's Avatar
ThaGlyde
Thats great. I knew there was something to it. Good luck.
Old Feb 28, 2011 | 07:10 PM
DrPlastic's Avatar
DrPlastic
Hey Glyde
Any idea on the adjustment of the EQ's I want to add more bass but can't seem to get it to work!
Old Mar 1, 2011 | 05:17 AM
ThaGlyde's Avatar
ThaGlyde
To be honest doc. I'm young so I just started pressing buttons untill I got what I was looking for. One thing to remember is that you can change the "frequency" as well as you average bass treble controls. I have mine turned up to about 120hz. But like I said, it only came with fooling with it for a while.
imskier2
Aug 29, 2017 05:59 AM
Kawickrice
Audio Systems
Feb 11, 2017 10:29 AM
D.L.ANDER
Audio Systems
Dec 10, 2014 07:57 PM
ParaGrunt
Audio Systems
Jan 11, 2011 10:37 AM
