P1353 Code Problem
Old Mar 5, 2011 | 03:52 PM
jackthemaniac's Avatar
jackthemaniac
3rd Gear
Default P1353 Code Problem
Hi everyone. I have an '06 Roadking and just upgraded the cams and oil pump. Afterwards I noticed a problem with my engine light coming on at high speeds (85-90) along with a hesitation as the throttle came down. Searching other posts, I have replaced the spark plug cables, new spark plugs, checked the exhaust pipes for leaks (which I did find one and since corrected). I'm still getting the engine light coming on around 70mph and what feels like a momemtary hesitation until the light goes out. I've check the diagnostics and get a P1353 code. Any ideas on what is going on and how to correct the problem? Thanks.
Old Mar 5, 2011 | 03:56 PM
MassHD's Avatar
MassHD
I have a list of the codes. Code P1353 is "Front Cylinder No Combustion". Hope this helps.
Old Mar 5, 2011 | 04:22 PM
blusmbl's Avatar
blusmbl
How radical of a change to the cam(s) was it, and did you retune the bike afterward?
Old Mar 6, 2011 | 09:16 PM
jackthemaniac
3rd Gear
I upgraded with the Herko kit and used Andrews 21 cams. All of that went well. No problems that with the upgrades it went smooth.
Old Mar 7, 2011 | 06:16 PM
roaddog's Avatar
roaddog
I think your next step is to check the coil.
mike513
Aug 28, 2017 07:08 PM
Powercat87
Jul 30, 2016 05:50 AM
arnieb
Jul 8, 2013 11:16 PM
tripacer1
Aug 31, 2012 08:32 AM
jorswift
May 27, 2010 08:12 AM
