Alpine IDA-X100M Install Question
Old Mar 10, 2011 | 11:44 PM
bpd138's Avatar
bpd138
Default Alpine IDA-X100M Install Question
I'm thinking of swapping out my stock HD Radio for the Alpine IDA-X100M. Mainly because I want to be able to control my Ipod through the head unit.
Can anyone tell me what I will need to complete this install? Will I need a radio adapter kit or will it just fit in the factory hole? I assume I will need some sort of switch interface so I can control the radio and ipod from the handlebars?
One last question, Is the Alpine IDA-X100M really waterproof or just water resistant? Will it stand up to a hard downpour?
Any help would be greatly appreciated.
Take care,
Willie
Old Mar 11, 2011 | 12:11 AM
mkguitar's Avatar
mkguitar
Hey Willie,
Why not the Harley-Davidson ipod interface then?
I test rode a CVO with this, my ipod touch in the rt saddlebag.
radio display showed song/artist etc
had full control with the stock switches- and it charges.
Now - here's what i didn't like!- I had to keep taking my eyes off the road to see what i was dialing up...
I'd be afraid that the distraction would get me in trouble.
so instead I have my ipod touch in a clear face holster clipped to my windshield bag. That way i can see the display while riding which is great if i am using a map or have directions on the screen.
i use the headphone out ( which has more gain than the line out from the 30 pin connector) ---dial up the adaptunes app, which does auto volume control---and i use a cable with a mic kit, which has an inline pause play switch- easy to pause at a toll booth, or anytime I need the sound off quick.
( I am cheap, so pleased that my best -so far- solution ran me less than $20 for holster, cable with switch, and charger)
I know alot of guys use a sony stereo with a biketronics interface to the bar controls, don't know if it accepts the ipod.
Mike
Old Mar 11, 2011 | 01:47 AM
roadgliderick's Avatar
roadgliderick
yes it does accept the ipod
Old Mar 11, 2011 | 07:04 AM
XXXRacing's Avatar
XXXRacing
I installed the IDA-X100 (non waterproof version) on my bike. I used the hawg wired radio bracket, don't see how you could install without as the radio is smaller than the stock one. I however had an amp installed so I did not buy an adapter to wire it in. (was just a ground, 12 V constant, 12V switched) I did use the PAC adapted to wire in the hand controls. That took a little time but worked well when I was done with installing it. The radio works well. I had the ipod hooked up and the sirius module. Loved it. At the time the stock Ipod interface was not available so I may have just gone that route.
Old Mar 11, 2011 | 05:32 PM
GLACIERPEARL's Avatar
GLACIERPEARL
Biketronics sells a clear "bubble shield" that you could keep in the hard bag. It just slides in the radio cavity,...for those rainy days !
Old Mar 11, 2011 | 05:40 PM
r8rs4lf's Avatar
r8rs4lf
I have the X-100. Used the hawgwired bezel and cradle. Also installed the ARC mini amp on top of radio. Bought an extension iPod wire and my iPod sits in a saddlebag guard bag. Controlled by the head unit. I also bought the hawgwired universal radio adapter to control the radio with hand controls.
It's all not cheap, but it all works perfect and I have no complaints.
Old Mar 11, 2011 | 05:42 PM
r8rs4lf's Avatar
r8rs4lf
Here is a link.
http://hawg-wired.com/catalog.php?cPath=2
Also installed the J&M 7.25's.
Old May 5, 2011 | 06:12 PM
StreetPilot's Avatar
StreetPilot
Originally Posted by XXXRacing
... I however had an amp installed so I did not buy an adapter to wire it in. (was just a ground, 12 V constant, 12V switched) I did use the PAC adapted to wire in the hand controls. That took a little time but worked well when I was done with installing it.
Can you give more info about what the "PAC" adapted to hand controls is and how you wire it in?
Thanks
Old May 5, 2011 | 11:44 PM
Garcou's Avatar
Garcou
Yep would be interested myself about that PAC unit
Old May 6, 2011 | 07:40 AM
baldeagle503's Avatar
baldeagle503
You will also need the special cable from alpine for the ipod interface, I forgot what number it is, but it tells you in the install directions. Costs about $20 on ebay. The connector that comes with the head unit is a USB interface and won't display all the song info. I can't say anything about the handlebar controls.
